How do I calculate Phase Angles?
  • Thread starter Thread starter shintashi
    Angles Phase
The discussion focuses on calculating phase angles in AC circuits using the equation tanθ = (XL - XC) / XR, where θ is the phase angle between current and voltage. The correct approach involves directly subtracting the reactance values (XL and XC) without squaring them, then dividing by the resistance (XR). Additionally, the process for calculating voltage utilizes the Pythagorean theorem, where the impedance is derived from the squared differences of reactance and resistance. The participants emphasize the importance of step-by-step calculations and suggest practicing with a slide rule for better understanding.
  • Understanding of AC circuit concepts, specifically reactance (XL and XC).
  • Familiarity with the tangent function and its application in trigonometry.
  • Knowledge of rectangular and polar coordinate conversions.
  • Basic proficiency in using scientific calculators for trigonometric functions.
  • Study the principles of AC circuit analysis, focusing on reactance and impedance.
  • Learn about rectangular to polar coordinate conversion techniques.
  • Practice using the Pythagorean theorem in electrical engineering contexts.
  • Explore advanced trigonometric functions and their applications in engineering problems.
Electrical engineering students, technicians working with AC circuits, and anyone seeking to improve their understanding of phase angles and impedance calculations.
shintashi
So I got to the part of my math/engineering textbook on vectors and scalars, and I've got to calculate phase angles and voltage. I see this equation, and I've tried doing it different ways but I don't get correct answers.
tanθ=XL−XC / XR
Angle θ represents the phase angle between the current and the voltage.
I thought I was supposed to square each value first,
then subtract C from L,
then divide by R
then get the square root of the result,
then push the inverse button + Tangent on the calculator to change the result into an angle in degrees.
I didn't do well with vector spaces in school and have trouble with them now.
Also, am I supposed to do any RMS stuff like root 2 over 2, since its AC, and implied? Or am I overthinking it?
XL and Xc are 180° out of phase. You can subtract one from the other directly, depending on which one is greater. You don't need rms values for impedance.
It helps to draw the picture first.
That makes it into an elementary trigonometry problem. Which you solve one step at a time...
1. Find what is impedance . You have to add in Rectangular coordinates (unless angle is same).
2. Divide voltage by that impedance. You have to divide in polar co-ordinates .
You'll get good at rectangular-polar conversion. Pythagoras Rules!
Doing these beginner exercises with a slide rule instills the "one step at a time" thinking method.
If you're using a calculator, force yourself to think in steps by writing down each step and its result , until the process becomes automatic..
thank you both! I was definitely overthinking it. The numbers aren't squared when doing the fraction portion to calculate phase angle.
it's just the bigger number minus the smaller number in C & L, and then divide by R. Once i have that value,
1. type in the (probably decimal) value into the calculator
2. push INVerse on the calculator
3. push TANgent. Boom, Phase angle.
Then for calculating the voltage, its Pythagoras: a^2 + b^2 = c^2,
1. with a = the result from C - L, then squared
2. b = Resistance, then squared
3. add these two together, which is the c^2 value
4. square root that value and I get my voltage.
I checked this process and i got the same results as the answers in the back of the book. :biggrin:
38K
15K
  • · Replies 49 ·
15K
