How do I change a poisson spreadsheet into a bivariate version?
  • Thread starter Thread starter pswirly
    Change Poisson
To convert a Poisson spreadsheet into a bivariate version, one must consider whether the two variables are independent or dependent. If independent, the Poisson distributions can be multiplied; however, if they are dependent, correlation information is necessary. A key restriction involves incorporating draw probability as a parameter, where the draw probability is calculated as the sum of the products of the two distributions. The user has noted that their current calculations yield a draw probability lower than the actual, indicating that additional factors, particularly draw probability, must be integrated into the Poisson distribution. To accurately modify the distribution, it is essential to account for these draw probabilities in the calculations.
pswirly
I have an excel spreadsheet that uses poisson to figure out the probability of correct scores in soccer matches.
How do I amend the spreadsheet to use a bivariate poisson distribution?
If the two variables are independent, just multiply the Poisson distributions of each. If they are not independent, what information about the correlation do you have?
1. There is additional restriction - draw probability as parameter for distribution. Draw - this is the case when M(t) = N(t).
In common Pdraw = sum(M(ti)*N(ti)), i = 0, 1, 2 ...
2. I have tried to multiply the Poisson distributions of each for calculation the spreadsheet, but calculated Pdraw is lower than fact Pdraw. And calculated data don't correlate with fact data. Results from this that I don't take into account some factors (first of all, draw probability), which shall correct Poisson distribution.
How I can take into account draw probability to modificate the Poisson distribution?
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
