How do I design a pressure vessel with given data?
The discussion revolves around the design of a pressure vessel, focusing on the calculation of internal pressure and diameter based on provided specifications, including material properties and safety factors. Participants explore the adequacy of the given data and the principles involved in pressure vessel design.
  • Homework-related
  • One participant presents the specifications for the pressure vessel, including the content, material strength, safety factor, and volume, and questions the sufficiency of the data for design calculations.
  • Another participant emphasizes the need for technical knowledge and adherence to design codes, specifically mentioning the ASME Boiler and Pressure Vessel code, and states that the provided information is insufficient for starting the design process.
  • A participant suggests that if this is an academic exercise, they can discuss the principles involved further.
  • One participant asks for clarification on the type of pressure vessel being designed, proposing two scenarios: a simple storage tank or a process vessel, indicating that the working pressure is crucial for calculations.
  • Another participant reiterates the need to determine the working pressure and encourages the original poster to think about the function of the pressure vessel and the source of pressure.
  • A suggestion is made to refer to an earlier thread for additional insights on pressure vessel design.
Participants generally agree that the provided data is insufficient for a complete design. However, there is no consensus on the specific working pressure or the type of pressure vessel, leading to multiple competing views on how to proceed with the design.
The discussion highlights limitations in the provided specifications, particularly the absence of a defined working pressure and the relationship between length and diameter, which are critical for calculating shell thickness.
billy_boy
I have been asked to design a pressure vessel and the data given to me for the problem is -
content -oil of density 0.9 g/ cm3.
material with ultimate tensile strength of 70,000 psi.
factor of safety 3.
volume 50 m3.
How do I calculate the internal pressure and diameter, which I will need to calculate the shell thickness.The relation between length and diameter is not given.Also, is the data given to me insufficient to design the pressure vessel?
Designing pressure vessels safely requires considerable technical knowledge and experience and they have to be designed to conform a pressure vessel design code .
ASME Boiler and Pressure Vessel code is used in many countries .
In any case you have not been given enough basic information to start the design process .
If this is a real design exercise then you will need to get professional help . If this is an academic exercise then we can discuss the principles involved a bit more if you wish .
OK .
First thing we need is the working pressure . You really need to be given this in the specification but if you have no guidance at all we'll use a fictional but realistic value for the type of pressure vessel under consideration .
Are we looking at :
(1) A simple storage tank where the only pressure comes from gravity acting on the contained oil ?
(2) A process vessel of some sort where pressure is probably going to be much higher ?
Only you can decide .
Nidum said:
OK .
Are we looking at :
A pressure vessel
  • · Replies 16 ·
  • · Replies 17 ·
15K
