How do I determine the tipping angle of a box on a truck?
  • Thread starter Thread starter Zach981
    Box Truck
To determine the tipping angle of a box on a truck, one must analyze the forces acting on the box, particularly the normal force when the box is about to tip. The correct approach involves using the tangent of the angle formed by the box's height and width to find the acceleration limit before tipping occurs. The equations for forces in both the x and y directions, along with net torque, should be set up properly to solve the problem. The solution involves recognizing that the acceleration can be calculated using the relationship a = g * tan(θ), where θ is derived from the box's dimensions. Understanding these principles is crucial for solving similar physics problems effectively.
Zach981
A truck is loaded with a large box, which is a uniform rectangular solid 1.8 m tall, 1.0 m wide, and 1.2 m deep.
The box sits upright on a truck with its 1.0 m dimension in the direction of travel, and the bed of the truck is sufficiently rough that the load cannot slide. How rapidly can the truck accelerate without tipping the box over? [Hint: Suppose the box is just starting to tip; where is the normal force acting?]
This is from the torque/equilibruim section of the physics textbook.
I set up a free body diagram, made three equations for the forces in the x direction, y direction, and the net torque. But mastering physics says my answer is wrong. How should I set up this problem?
Hi Zach981! :wink:
Show us your equations. :smile:
tiny-tim said:
hi zach981! :wink:
What did I do wrong?
I have 2 hours left to finish this assignment, does anyone here have know what to do?
Forget it, figured this out myself,
μ = cosθ/sinθ
where:
tanθ = 1.8 m/ 1 m
then, a = μg
just in case anyone else has to do these stupid mastering physics assignments.
Hi Zach981! :smile:
(just got up :zzz:)
(in future, show your working at the start, as per the forum rules, and you'll receive help much sooner)
μ = cosθ/sinθ
where:
tanθ = 1.8 m/ 1 m
then, a = μg
sorry, but both solutions are the wrong idea
moment of inertia has nothing to do with it … that would only matter if you were interested in the rate of turning
the coefficient of friction, µ, also has nothing to do with it … the tipping angle would be the same even if the box had a fixed pivot at the corner, wouldn't it? :wink:
your answer (a = gtanθ) is correct, but you need to rewrite your reasoning :smile:
(btw, you could achieve the same result more easily, if your professor allows you to use non-inertial frames, by adding a horizontal "fictitious" force of -ma :wink:)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
