How do I find deflection in this beam?
  • Thread starter Thread starter raymanmusic
    Beam Deflection
The discussion focuses on calculating the deflection at point C of a beam with a roller connection at B and an external pin at A. Key parameters include the modulus of elasticity (E = 2.1 × 105 N/mm2) and the area moment of inertia (I = 57.9 × 106 mm4). The distances AB (3 meters) and BC (2 meters) are critical for the calculations. The final calculated deflection at point C is approximately 5.92 mm, confirmed by multiple methods and calculations.
  • Understanding of beam deflection principles
  • Familiarity with the unit load method for structural analysis
  • Knowledge of the modulus of elasticity and area moment of inertia
  • Ability to perform calculations involving significant figures
  • Study the unit load method for beam deflection analysis
  • Learn about the effects of different types of supports on beam behavior
  • Explore advanced beam deflection formulas and their applications
  • Investigate the significance of significant figures in engineering calculations
Structural engineers, civil engineering students, and professionals involved in beam analysis and design will benefit from this discussion.
raymanmusic
How do I find deflection (displacement) in point C at the end of the beam? Answer is to be given in mm. There is a roller connection (only Fy) in B and an external pin in A (Fy and Fx). The module of elasticity and area moment of inertia is given.
Relevant equations:
1. http://en.wikipedia.org/wiki/Deflection_(engineering)
2. http://www.advancepipeliner.com/Resources/Others/Beams/Beam_Deflection_Formulae.pdf
Here is a solution to a similar problem: https://dl.dropboxusercontent.com/u/11241083/beer_mecanica_4e_solucionario_c09_a.pdf
First, you are going to need to know E, I, and LAB and LBC.
I tried solving this using the unit load method.
I = 57.9 * 10^6 (mm^4)
E = 2.1 * 10^5 (N/mm^2)
AB distance = 3 meters
BC distance = 2 meters
https://dl.dropboxusercontent.com/u/11241083/Solution_Beam_Problem.pdf
raymanmusic: I currently got an answer different from your post 3 answer for deflection of point C, using a different method.
Relevant equations:
You failed to use the template which was provided. Do not do this again, we have rules for a reason and they must be followed.
Answers discussed in OP's first thread.
https://www.physicsforums.com/showthread.php?t=711176
raymanmusic: I now also used a second method, and I got exactly the same answer I got using a completely different method in post 4. Therefore, I am about 99 % certain I have the correct answer.
You did excellent work in post 3, but it appears you made one main mistake, as follows. Delete your unit load at x2 = 666,67 mm, and then try your solution again. You do not want to find deflection at x2 = 666,67 mm, and you therefore should not place a unit load at x2 = 666,67 mm. Try again.
By the way, always maintain four significant digits throughout all your intermediate calculations, then round only the final answer to three significant digits. E.g., -7,556 kN, not -7,56 kN.
Thanks for helping me out nvn. Do I place the unit load where I want to find deflection? What about the triangle load? Should I ignore it when I calculate mx2? What did you get as your final answer in mm?
raymanmusic: Yes, place the unit load where you want to find deflection. Yes, ignore the triangular load when you compute mx1 and mx2. I will let you know if you obtain the correct final answer, if this is not a test question.
I got approximately 5.922 mm as my final answer. Is this close to the correct answer?
Excellent work, raymanmusic. Your answer is correct (5.921 54, which rounds to 5.92 mm).
By the way, N/mm^2 is called MPa. If a derived unit has a standardized special name, then only the standardized[/color] special name should be used. E.g., 210 000 MPa, not 210 000 N/mm^2.
Thanks for the help nvn. I'll ask you if I have more problems I'm stuck with.
deflection101 came with a formula for this case,Where is it?
Yc=[wb^3(5L-2b)+30PLb^2] / 90
given: w=10kn/m
p=8kn/m
a= 3
b=2
EI=1 (to simplify)
Ans.:yc= - 72 (-160/3 - 56/3)
it doesn't get any better than this! yc= - 72
EIy(x)=wx/360b(3x^4-15bx^3+30b^2X^2-30b^3X-20ab^3)+Px/6(x^2-3bx-2ab)
EIy(2)=-72
y=- 72/EI EI=read above
  • · Replies 22 ·
