How do I know that the angular acceleration is the same for both wheels?
In summary, the two wheels are linked, forcing them to rotate in sync and have identical angular acceleration. This is achieved through a parallelogram four-bar linkage, where the radii of the wheels, the distance between the points, and the distance between the centers of the wheels must all be equal. The angular velocities and accelerations of the two wheels will always be equal, though their values may not be constant during each rotation. The system can be analyzed using free body diagrams and conservation of energy.
simphys
322
45
Wheel C has a mass of 60 kg and a radius of
gyration of 0.4 m, whereas wheel D has a mass of 40 kg and
a radius of gyration of 0.35 m. Determine the angular
acceleration of each wheel at the instant shown. Neglect the
mass of the link and assume that the assembly does not slip
on the plane
ok
how do I know that both angular accelerations are the same for both wheels here? should I apply relative motion analysis for the acceleration at A(with ##a_x,A and a_y,A##) and B(with ##a_{x,B} and a_{y,B}##) here, or is just a_A=r*alpha_C and a_B = r*alpha_D enough from which a_A=a_B and thus both have the same acceleration. Thanks in advance
The wheels are linked, same as if the rod connected via the axles, but this is more of a locomotive link. Point is, it forces both wheels to rotate in sync and thus have identical angular acceleration. Were they not linked, the rear one (D) would accelerate faster.
Calculation of that angular acceleration rate involves the total mass, total moment, and slope angle.
Likes FactChecker, simphys and Lnewqban
simphys said:
how do I know that both angular accelerations are the same for both wheels here?...
How would you define angular acceleration for each wheel?
Likes simphys
Change of angular velocity over dt, but what i meant was, if I where to actually show that the angular velocities are the same, can I say that a_A=0.9 x alpha_C due to rolling without slip, or is that only for the acceleration at the COG
I don’t know exactly what kind of answer is expected from you, but the following may help you.
Let’s forget about accelerated movement for a second.
For the shown mechanism to work beyond a fraction of one turn, the tangential velocity of point A and point B must be identical, not only in magnitude but also in direction at any instant.
In order to achieve the above (regardless constant or for accelerated rotational speed), the wheels must have the same radii, as well as both points, and the linkage length or linear distance between A and B must be equal to the distance between the centers of the non-slipping wheels.
The surface, the wheels and the link form what is called a parallelogram four-bar linkage.
Please, see:
https://en.m.wikipedia.org/wiki/Four-bar_linkage#Classification
Likes scottdave
There's nothing to show. You can simply state that the angular accelerations must be equal. It should be clear from the geometry - look at @Lnewqban's excellent animation.
(At any instant the angular velocities and accelerations of A and B must be equal - though that doesn't mean their values are necessarily constant during each rotation.)
The 'trick' is to realise that the link could be in tension, compression or unstressed. For the orientation shown, you can draw free body diagrams of A and B and set up some equations. I'd guess it then involves some messy algebra/arithmetic.
[Minor edits made.]
Likes scottdave
Just to sketch the system, let us state conservation of energy with no slip, i.e.
[tex]\frac{1}{2}(M r^2 +I )(\frac{d\theta}{dt})^2 + Mg(h-h_0)=0[/tex]
where
[tex]h_0-h=r\theta sin\phi[/tex]
[tex]M=M_C+M_D[/tex]
[tex]I=I_C+I_D[/tex]
r is radius of wheel. h_0 is height of some point of assembly when it is at rest initially. h is height of that point at time t. ##\phi## is angle of slope. ##\theta## is wheels rotation angle which is zero initially. The equation has a form of
[tex] (\frac{d\theta}{dt})^2=2a\theta[/tex]
where a is constant angular acceleration.
where
(At any instant the angular velocities and accelerations of A and B must be equal - though that doesn't mean their values are necessarily constant during each rotation.)The 'trick' is to realise that the link could be in tension, compression or unstressed. For the orientation shown, you can draw free body diagrams of A and B and set up some equations. I'd guess it then involves some messy algebra/arithmetic.
[Minor edits made.]
Please, see:
OH I see, thank guys I get it now! .. Had a bit of difficulty 'actually' visualizing it.
And I have a related question to this one actually, one that problem from a couple days ago, which I still haven't figured out. If we look at this structure, will the link AB also undergo translation due to the fact that link AC and link BD are at the same height or will it have an angular acceleration? I think it'll only translate, but I can't really visualize it for sure.
Thanks in advance.
Ideally, a different question should be in its own thread. The risk is that you now get interleaved replies to 2 different questions - causing great confusion!
Thanks in advance.
Please ignore the deleted comment below. I now believe the question is only about the system at a particular instant in time when the configuration is as shown in the diagram. My deleted comment is inapplicable because AC and BD would not have both rotated through 90º in the same time.
To help 'visualisation' it sometimes helps to consider an extreme case, e.g. suppose:
Link AB (4m long) is removed.
AC rotates 90º clockwise about C.
BD rotates the same angle, 90º clockwise, about D.
Is the line AB still horizontal? Is the distance between A and B still be 4m?
Likes simphys and Lnewqban
Can you see the following?
Point B will “drop” faster than point A.
Link AB will have a clockwise rotation respect to A or B.
Likes simphys
Steve4Physics said:
Ideally, a different question should be in its own thread. The risk is that you now get interleaved replies to 2 different qestions - causing great confusion!To help 'visualisation' it sometimes helps to consider an extreme case, e.g. suppose:
it'll 'rotate' about A clockwise, and yes my apologies.
oh.. wait so I'm confused. If I would consider the extreme case of A and B horizontal to the right, I'd say that it rotates about A. But when I look at it by considering that B will drop faster due to the link being smaller than I see a rotation about B clockwise.
Apologies, I think I misunderstood the question. I have updated Post #9.
I now believe that the diagram (in Post #8) only specifies what is happening at a particular instant, when AB’s angular velocity is instantaneously zero (which is why “##\omega = 0##” is specified for AB on the diagram!).
Ath the instant shown on the diagram:
The velocity of point A is ##\omega_A r_A = 3 \text {rad/s} \times 2 \text{m} = 6## m/s horizontally to the right
The velocity of point B is ##\omega_B r_B = 6 \text {rad/s} \times 1 \text {m} = 6## m/s horizontally to the right.
So at the instant depicted in the diagram, AB’s instantaneous velocity is 6m/s horizontally to the right and its instantaneous angular velocity is zero.
A short time one or both of the angular velocities must change in order that length AB is maintained at 4m. But that’s not what the question is about.
Well, that’s my interpretation.
Likes simphys
well let's put it like that, so on two of the links there's no angular acceleration given. The following is where I had my doubts: So for link AB for the moment equation, the doubt was whether the angular acceleration will also be 0 at that point then or whether I should take it as an unkown. And for link BD it's obvious that there's an angular acceleration (which is another unkown) as there's a force exerted on link AC whilst they're connected
No. You are given two of the three instantaneous angular accelerations. (I won’t keep stating ‘instantaneous’ but it is implied.). AC’s angular acceleration is given as 2rad/s² clockwise about C. AB’s angular acceleration is given as 0.
EDIT - apologies. You are correct. I'm carelessly muddling-up angular velocity and angular acceleration. Sorry for the confusion.
Can I suggest you
a) Find the linear acceleration of point A. This gives the linear acceleration of point B.
b) Use this to find the angular acceleration of BD.
You might then want to draw three free body diagrams (one per link) and construct relevant equations.
Likes simphys
Can I suggest you
Hello that is indeed what I did. I had 9 unkowns, 5 forces with 5 eqn's of motion from the 3 bodies and the rest from the kinematics. but.. the thing is. I took AB's angular acceleration as an unknown and I indeed got a nonzero value. And it says in the picture that only the angular velocity is 0, so howcome can I then conclude that its' angular acceleration is also zero? (my initial question was similar)
Sorry. My mistake (Instantaneous) angular velocity = 0 certainly does not require that angular acceleration = 0.
I'll give it some further thought!
Likes simphys
thanks a lot! but I think you were totally correct in your previous comment. :) Knowing that in the extreme cases it's not horizontal anymore gives us an indication that there actually is an angular acceleration for the middle link.
At the very instant that the posted diagram shows, the tangential velocities of A and B must be identical, not only in magnitude but in direction.
An instant later, the geometry makes that equality disappear.
The reason is that the directions of both tangential velocities begin to diverge, as each must keep perpendicular to each rotating link AC and BD.
We then have two velocity vectors at the ends of link AB, with a distance separating their lines of action, and the movement of that link respect to the ground of fixed pivots C and D must show some rotation.
Further thoughts...
The problem is to write equations which allow ##F## to be found. Note that ##F## acts in the +x direction.
We can resolve the reaction forces at A and B into x and y components. Only the y-components can cause AB to have angular acceleration about AB’s centre of mass. And these y-components contribute zero moment to AC and BD.
It should be possible to construct a set of equations which only use x-direction forces. This means the y-components - and therefore any angular acceleration of AB - can be ignored.
The two forces determining AC’s angular acceleration are ##F## and the x-component of the reaction at A; call it ##R_{Ax}##.
The single force determining DB’s angular acceleration is the x-component of the reaction at B; call it ##R_{Bx}##.
The two forces determining AB’s linear x-acceleration are ##R_{Ax}## and ##R_{Bx}## (well, technically the Newtpn's 3rd law partners of these).
The angular acceleration of DB and the linear acceleration of AB can be found from the data (see Post #12). You should then end up with three equations and three unknowns: ##F, R_{Ax}## and ##R_{Bx}##.
Thanks in advance.
On xy Cartesian coordinate
[tex]C(0,0)\  D(4,1)[/tex]
[tex]A(2\cos\theta, 2\sin\theta)[/tex]
[tex]B (\cos\phi+4, \sin\phi+1)[/tex]
[tex]AB^2=16=(\cos\phi+4-2\cos \theta)^2+(\sin\phi+1-2\sin\theta)^2[/tex]
where
[tex]\theta_0=\phi_0=\frac{\pi}{2}[/tex]
initially. This equation of geometry should provide the relation between ##\theta## and ##\phi## during the motion. From this I observe
[tex]\dot{\phi}_0=2\dot{\theta}_0[/tex]
[tex]\ddot{\phi}_0=2\ddot{\theta}_0[/tex]
if I do not fail.
1. How do I calculate the angular acceleration for each wheel?
To calculate the angular acceleration, you can use the formula: angular acceleration = (final angular velocity - initial angular velocity) / time. Make sure to use the same units for time and angular velocity for accurate results.
2. Can I assume that the angular accelerations are the same for both wheels?
No, you cannot assume that the angular accelerations are the same for both wheels. It is important to measure and calculate the angular acceleration for each wheel separately to ensure accuracy.
3. What factors can affect the angular acceleration of a wheel?
The angular acceleration of a wheel can be affected by factors such as the mass of the wheel, the torque applied to the wheel, and the friction between the wheel and its axis of rotation. Other factors, such as air resistance and surface conditions, can also play a role.
4. Why is it important to know the angular acceleration for both wheels?
Knowing the angular acceleration for both wheels is important because it can help determine the overall motion and stability of the object the wheels are attached to. It can also provide valuable information for designing and optimizing mechanical systems.
5. Can the angular acceleration of a wheel change over time?
Yes, the angular acceleration of a wheel can change over time. Factors such as changes in torque, mass, or surface conditions can cause the angular acceleration to vary. It is important to continuously monitor and adjust for these changes to maintain accurate measurements.
