How do i show if this is associative or not?
  • Thread starter Thread starter gavin123
    associative
The discussion focuses on determining whether the operation defined by (x*y) = x + 2y + 4 is associative. Participants clarify that using the asterisk (*) as an operator can cause confusion, suggesting the use of a distinct symbol like ⊗ instead. They emphasize the importance of correctly applying the operation in expressions and using parentheses to avoid misinterpretation. The conclusion drawn is that the operation is not associative, as demonstrated by the unequal results from the two sides of the associative property. Overall, clarity in notation and careful application of the operation are essential for understanding the problem.
gavin123
(x*y)=x+2y+4
first i did this but I'm not sure if it is correct
(x*y)*z=x+2y+4*z=x+2y+4+z+1
x*(y*z)=x*y+2z+4=x+y+2z+4+1
No, it is not correct. Study the definition closely. Remember that x does not stand for "x", but for "any expression to the left of "*". Vice versa for y.
I don't understand what you mean?
I think Svein means that instead of using the notation (x*y) = x + 2y + 4, you should use something like (x⊗y) = x + 2y + 4.
Using '*' as an operator confuses, as we are used to thinking of '*' as indicating multiplication of the quantities x and y.
By using the special ⊗ symbol as an operator, it becomes less confusing.
For example, if we wrote (6⊗y), that would mean 6 + 2y + 4;
likewise (x⊗6) would mean x + 2*6 + 4;
(g⊗x) = g + 2x + 4
Oh ok then did I write it out correctly
It's not clear what you mean here.
To take one of the items from the OP:
(x ⊗ y) ⊗ z would mean finding out what (x ⊗ y) was first and then combining that quantity with z.
You could re-write the original expression as
(x ⊗ y) ⊗ z = (x ⊗ y) + 2z + 4 and then expand (x ⊗ y) according to the definition.
gavin123 said:
(x*y)=x+2y+4
I don't see any problem in using the asterisk (*) for the operation defined here. Just be sure not to confuse it with traditional multiplication.
When you write:
(x*y)*z = x+2y+4*z ,​
you really should use parentheses,
(x*y)*z = ( x+2y+4 )*z​
What you write after that is incorrect. It should be equal to ( x+2y+4 ) + 2z + 4 , etc.
Not showing all my steps, NOT associative.
The two sides give x+2y+2z+8 and x+2y+4z+12, so these are unequal.
so if (x*y)=x+2y-xy Then
x*(y*z)=x+2(y+2z-yz)-x(y+2z-yz) and
(x*y)*z=(x+2y-xy)+2z-(x+2y-xy)z
Yes.
But it's not clear, looking at that, whether those two expressions are equivalent.
they are not the same
i know that, but it's not all that clear from those two expressions.
