How do I solve sqrt(5x + 3) = -2?
  • Context: MHB
  • Thread starter Thread starter littapple
The equation sqrt(5x + 3) = -2 has no solutions in the realm of real numbers. Squaring both sides leads to the incorrect statement 2 = -2, indicating a fundamental issue with the original equation. The square root function, defined to return only non-negative values, confirms that sqrt(5x + 3) cannot equal a negative number. Therefore, the conclusion is that this equation does not yield any valid solutions.
  • Understanding of square root properties
  • Familiarity with basic algebraic manipulation
  • Knowledge of real versus complex numbers
  • Ability to identify extraneous solutions in equations
  • Study the properties of square roots and their definitions
  • Learn about complex numbers and their applications in equations
  • Explore methods for identifying and eliminating extraneous solutions
  • Practice solving equations involving square roots and inequalities
Students studying algebra, educators teaching mathematical concepts, and anyone seeking to understand the limitations of square root equations in real number contexts.
littapple
What's the answer to the problem sqrt(5x+3)=-2, solving for x?
If you square both sides, you get 2=-2, which is wrong. Does it have to
do with complex/imaginary numbers? Or does it have no answer at all?
Mathematics news on Phys.org
Re: What is sqrt(5x+3)=-2? Help me solve?
If you square both sides you get
$$5x+3=4$$
And following that gives
$$5x=1$$
$$x=\frac{1}{5}$$
However, when putting in the value of x into your original equation, we want to take only the positive root, so your equation has no solutions.
When working with real numbers, \sqrt{a} is, by definition, the positive number whose square is a. You should have been able to see, immediately, that \sqrt{5x+3}= -2 has NO solution.
  • · Replies 16 ·
  • · Replies 22 ·
