How do magnetic fields provide thermal insulation
Magnetic fields in tokamak reactors, such as those used in fusion power experiments, do not provide thermal insulation but instead maintain physical separation between the plasma and reactor walls. The plasma, which reaches temperatures of 1 million Kelvin, is held in place by the Lorentz force, preventing direct contact with the reactor's inner surfaces. Heat transfer from the plasma to the reactor core is minimal due to the lack of a medium for convective and conductive heat transfer, and the reactor walls are designed to have low emissivity to reduce radiative heat transfer.
  • Understanding of tokamak reactor design and operation
  • Familiarity with the Lorentz force equation: F = q(E + v x B)
  • Knowledge of plasma physics and ionized particle behavior
  • Basic principles of heat transfer, including conduction, convection, and radiation
  • Research the design and function of tokamak reactors in fusion energy
  • Study the principles of plasma confinement and stability in magnetic fields
  • Explore heat transfer mechanisms in high-temperature plasma environments
  • Investigate materials used in reactor walls to optimize thermal insulation and emissivity
Physicists, engineers, and researchers involved in fusion energy development, as well as students studying plasma physics and thermodynamics.
Ian_Brooks
some Fusion power experimental reactors use tokamaks to contain plasma using strong magnetic fields. However this plasma is at a sizzling 1M Kelvin so how is this level of thermal insulation engineered, using magnetic fields?
The magnetic field doesn't provide insulation it simply holds the electrically charged plasma away from the walls.
Heat isn't the same as temperature, the sparks from a sparkler are at >1000 deg C but don't contain very much heat.
The plasma is primarily ionized particles. The Lorentz force is
F = q(E + v x B)
where q is particle charge, v is particle velocity, and B is magnetic field. The v x B term causes the ionized particles to move in orbits perpendicular to the magnetic field, similar to ions in a cyclotron.
then what stops the core from melting? I'm certain plasma would be quite hot
What stops the core from melting is that heat doesn't transfer at a high enough rate form the plasma to the core. Convective and conductive heat require a medium for transport. I'm not sure about the magnitude of radiative heat transfer from plasma though but I would assume the walls of the reactor would have a very low emissivity.
The tokamak is a donut shape. The plasma is in a ring inside the donut in a very high vacuum it doesn't (ideally) touch the inner or outer walls.
Strong magnetic field provides physical separation of the plasma tore and TOKAMAK walls. Plasma itself at these densities and temperatures is not quite transparent for the "light" - it radiates mostly from its surface.
Bob_for_short.
  • · Replies 42 ·
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 198 ·
15K
