How Do Plastic Sheets Affect Young's Interference Pattern?
YoungILoveYou
Hello, I' m an italian student, so exscuse for my bad english.
My problem:
A device for the experiment of the two splits of Young is considered in which the distance between the splits it is d=0.30mm and the distance from the screen is L=1m. Two thin transparent plastic sheets (n=1.50) of thickness 0.050mm and 0.025mm are placed dinanzi to the advanced and inferior split respective. To discuss like modification the figure of interference observed on the screen and the distance between two max of interference.
Hi Young,
What have you done with this problem so far? Have you tried to calculate the effective difference in the path length? If you share your thoughts/ideas in this problem, it will be easier for us to help.
Also, what's "dinanzi"? Is it an Italian word?
Ehm, yes,some trouble with google translator :)
"dinanzi"= in front
If you want, edit my first message. Thanks
My problem is that I do not succeed to take advantage of the various measures of two slits.Usuallly I have only worked with one interference slit.
I creed that in reality is from only using one formula like this:
[tex]2nd=(m + 1/2) \lambda[/tex]
where
lambda is the distance, n=1.50, d= thickness of slit ad m=0,1,2..
