How Do R5 and R6 Affect Vo and ia in a Circuit with Parallel Resistors?
  • Thread starter Thread starter Cisneros778
The discussion focuses on the impact of resistors R5 and R6 on the output voltage (Vo) and current (ia) in a circuit with parallel resistors. It is established that R5 and R6 do not cancel out but rather do not contribute to the voltage drop due to no current flowing through them. The correct approach involves analyzing the two voltage dividers formed by the remaining resistors to determine the midpoint voltage. The conclusion is that Vo is not 0V, contrary to initial assumptions.
  • Understanding of Ohm's Law (V = i * R)
  • Knowledge of voltage dividers in electrical circuits
  • Familiarity with parallel resistor configurations
  • Basic circuit analysis techniques
  • Study voltage divider circuits and their applications
  • Learn about parallel resistor calculations and their effects on circuit behavior
  • Explore advanced circuit analysis techniques, such as nodal analysis
  • Investigate the impact of current flow on voltage across resistors
Electrical engineering students, circuit designers, and anyone involved in analyzing or designing circuits with parallel resistors.
Cisneros778
Determine ia and Vo
V=0.4 V, R1 = 7kΩ, R2 = 28 kΩ, R3 = 43 kΩ, R4 = 31 kΩ
V= i*R
Does R5 and R 6 cancel out since the pair of parallel resistors share a common node, making Vo - 0 V?
They don't "cancel out" (weak terminology). There is no current going through them so no voltage drop across them. Better to say that their values are not relevant to the solution of the problem. Vo is not 0V. You have 2 voltage dividers-- evaluate the midpoint voltage of both of them.
Thank you.
