How Do We Derive the Transmission Line Equations Using Differential Methods?
1 reply · 3K views
yayscience
Eqn. (2.1)
[tex]\frac{\partial v}{\partial z} = -L \frac{\partial i}{\partial t}[/tex]
Eqn. (2.2)
[tex]\frac{\partial i}{\partial z} = -C \frac{\partial v}{\partial t}[/tex]
Eqn. (2.5)
[tex]v(z,t)=V^+f(t-\frac{z}{v_p})+V^-f(t+\frac{z}{v_p})[/tex]
From the book I'm reading:
"By substituting Equation (2.5) into Equations (2.1) and (2.2), we
determine that the current has the form:"
[tex]i(z,t)=\frac{V^+}{Z_0}f(t-\frac{z}{v_p})+\frac{V^-}{Z_0}f(t+\frac{z}{v_p})[/tex]
So, I've seen this derivation about four different ways, and I know this is the result, but I can't see what moves I need to substitute 2.5 into 2.1 and 2.2 to get 2.5. Can someone please enlighten me? Thanks all!
yayscience said:
Eqn. (2.1)
Eqn. (2.2)
Eqn. (2.5)
Just some preliminaries first. If you differentiate 2.1 wrt "t" and 2.2 wrt "z" (and then repeat the other way around) you get the following second order PDE's.
[tex]\frac{\partial^2 v}{\partial z^2} = L C \frac{\partial^2 v}{\partial t^2}[/tex]
[tex]\frac{\partial^2 i}{\partial z^2} = L C \frac{\partial^2 i}{\partial t^2}[/tex]
These separable PDE's give the motivation for the form given in 2.5 and tell us that the phase velocity is:
[tex]v_p = \frac{1}{\sqrt{L C}}[/tex]
Since the above second order PDE's tell us that i(z,t) will be in the same form as v(z,t) we can therefore write:
[tex]i(z,t)=I^+ \, f(t-\frac{z}{v_p})+I^- \, f(t+\frac{z}{v_p})[/tex]
By differentiating the above wrt "t" and differentiating 2.5 wrt "z" and substituting into 2.1 we can equate coefficients to show the following:
[tex]I+ = \frac{V^+}{L v_p} = \frac{V^+}{Z_0}[/tex]
[tex]I- = - \frac{V^-}{L v_p} = - \frac{V^-}{Z_0}[/tex]
Hope that helps.
