How do we get to the concept of kinetic energy?
The discussion revolves around understanding the transition from the conservation of momentum to the concept of kinetic energy in the context of elastic collisions. The textbook introduces the idea of elasticity through the analysis of a bouncing ball, leading to the formulation of kinetic energy as 1/2 mv^2. Participants clarify that the conservation of energy in elastic collisions involves both momentum and kinetic energy, and the factor of 1/2 arises from the work-energy theorem. There is an acknowledgment that this derivation may not be covered in high school textbooks, but is commonly found in university-level physics. The conversation emphasizes the importance of proper terminology and understanding the foundational principles in mechanics.
Robin04
Hi,
I'm reading a high school textbook about mechanics. It's amazing how the author draws up the problems and solves them by introducing a new consistent concept.
Now I'm reading about collisions. He writes the conservation of momentum but the problem is that we have two unknowns in one equation so another one is needed. He defines beautifully the concept of elasticity by analyzing the bouncing of a ball dropped from a certain height (with geometric sequence) thus solving the problem, we have the second equation. With some simple math he changes it to a form which is very close to the conservation of kinetic energy (only the 1/2-s are missing) then he states that by taking the half of mv^2, so 1/2 mv^2 we get a new notion which is the kinetic energy. I don't really get this part, I feel he's missing something or there's another way to get to the kinetic energy. He doesn't say anything about why we have to multiply the terms (that we got from a very logical thought) with 1/2.
Thanks for you help! :)
Okay, I think I know where you're wanting to head, but I'm going to need more clarification before I answer in full.
First, a few things.
These aren't mere notions, they're proven theories, so proper terminology will help. :)
Are you simply asking how he's able to go from Conservation of Momentum to the Conservation of Energy? Or is it more complex and you're just not sure how to articulate that? It sounds like he's discussing the Conservation of Energy in an Elastic Collision. Elastic collisions conserve kinetic energy as well as momentumIt would really help if you could at least give us the equations you're seeing.
Conservation of Momentum (Elastic collision): m1v1i + m2v2i = m1v1f + m2v2f
Conservation of Energy (Elastic Collision): ½m1(v1i)2 +
½m2(v2i)2 = ½m1(v1f)2 + ½m2(v2f)2
It's possible he may be doing just a straight substitution, but I have no way of knowing until you provide further information. Do these equations look familiar, or close to what you're seeing?
There is, by associating the change in an object's kinetic energy with the work done on it by an external force, via the work-energy theorem.
If you require that W = KEfinal - KEinitial, you get the 1/2 in the KE equation automatically.
http://faculty.wwu.edu/vawter/physicsnet/topics/Work/WorkEngergyTheorem.html
Every uinversity-level intro physics textbook covers this; don't know about high school textbooks. It's been a long time since I used one of those. :oldwink:
Likes Robin04
Yep--that's exactly what I was waiting for her to confirm with a new reply before showing her the step-by-step derivation from the Definite Integral, but needed to make *sure* that's where she was headed.
Eh, well. NO need for it now.
Likes Robin04
Thank you for your answers, Opuscroakus and jtbell! :)
Many do , if not all , I believe .
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
