How can we use hints to prove divisibility of Fibonacci numbers?
  • MHB
  • Thread starter evinda
In summary, the conversation involves discussing the relationship between $m=n^{13}-n$, where $n>1$, and the $m$-th Fibonacci number, $F_m$. The hint given is to show that $a^{13} \equiv a \mod{2730}$, which can be deduced using Fermat's little theorem and the fact that $2730=2\cdot 3\cdot 5\cdot 7\cdot 13$. The question at hand is how to use this hint to prove that $30290 \mid F_m$. The suggestion is to use the fact that $n\mid m \Rightarrow F_n \mid F_m$ and determine if it can be applied in this
evinda
MHB
3,836
Hello! (Wave)
I want to show that if $m=n^{13}-n$ and $n>1$ then $30290 \mid F_m$. (Hint: Show first that $a^{13} \equiv a \mod{2730}$.)
$F_m$ is the $m$-th Fibonacci number.I have shown the hint as follows:
$2730=2 \cdot 3 \cdot 5 \cdot 7 \cdot 13$.
Using Ferma's little theorem, we deduce that $a^{13}\equiv a \pmod{5}$, $a^{13}\equiv a \pmod{2}$, $a^{13}\equiv a \pmod{3}$, $a^{13}\equiv a \pmod{7}$ and $a^{13}\equiv a \pmod{13}$.Since $2,3,6,7,13$ are all relatively prime, we deduce that $2730 \mid a^{13}-a$.
But how can we use the fact that $a^{13} \equiv a \mod{2730}$ in order to deduce that $30290 \mid F_m$ ? (Thinking)
Mathematics news on Phys.org
Hey evinda! (Wave)
I think we need another hint.
Something like $n\mid m \Rightarrow F_n \mid F_m$.
Can we use that? Or something else? (Wondering)
1. How do we know when to use a hint?
Hints are usually provided when a problem or task is particularly challenging or complex. If you have been stuck on a problem for a while and are struggling to make progress, it may be a good time to use a hint.
2. Can we use hints for any type of problem?
Hints can be useful for a wide range of problems, but they are not always available or applicable. Hints are most commonly used in fields such as math, science, and logic-based puzzles.
3. How do we access and use a hint?
The method for accessing and using a hint may vary depending on the source. Some hints may be provided in written form, such as in a textbook or online resource. Others may be given verbally by a teacher or colleague. To use a hint, carefully read or listen to the information provided and apply it to your problem.
4. Will using a hint give away the answer?
It is important to carefully consider the level of detail provided in a hint before using it. Some hints may provide a direct answer, while others may simply give a helpful hint or direction. It is ultimately up to the individual to decide how much information they want from a hint.
5. Can we use multiple hints for the same problem?
Yes, you can use multiple hints for the same problem. However, it is important to try and solve the problem on your own before relying on hints. Using multiple hints can also help you to better understand the problem and improve your problem-solving skills.
