How Do You Calculate Airflow and Pressure Changes in a Duct System?
The discussion revolves around calculating airflow and pressure changes in a duct system, focusing on a specific homework problem involving fluid mechanics. The scope includes theoretical applications of Bernoulli's Equation and practical calculations related to volume flow rate, mass flow rate, and pressure at different points in the duct.
  • Homework-related, Technical explanation
  • The problem involves a horizontal duct with specific dimensions and conditions, requiring calculations of various flow parameters.
  • One participant questions the accuracy of the water gauge reading at position (1), suggesting that a height of 215 mm is more reasonable than initially interpreted as 215 m.
  • Another participant emphasizes the importance of demonstrating effort in seeking help, indicating that simply stating one is struggling is insufficient.
Participants do not reach a consensus, as there is a mix of concern regarding the interpretation of the water gauge reading and the expectations for assistance in the forum.
There are unresolved assumptions regarding the accuracy of the water gauge reading and the implications of losses in the duct system calculations.
zakf355
fluid mechanics question help!?
Air flows through a horizontal duct of dimensions 300 x 300 mm with a velocity of 15 m/s. At position (1) in the duct a water gauge (water manometer) registers a hieght of 215mm. The duct bends downwards and reduces in size to 240 x 240 mm, dropping a distance of 12 m to position (2). the specific volume of the air is 0.85 m^3 / kg and this may be taken as constant. Determine:
a) volume flow rate and mass flow rate.
b) pressure at (1) in kPa
c) The Velocity at (2)
d) pressure at (2) in kPa (guage) and mm water gauge if losses are neglected.
e) pressure at (2) in kPa (gauge and mm water gauge if losses are 10% of the total head at (1) and elevation (2) is used as datum
mass flow rate = v A relative density
im struggling guys
I'm not surprised that you're struggling. Are you sure that the water gauge at point 1 reads 215 m? That's a pretty large water gauge, equal to the height of a 70 story building. BTW, atmospheric pressure is about 10 m W.G.
haha its mm. silly me :/
You've got to show some effort to get help from PFers. That's the rules. "I'm struggling" isn't good enough.
