How Do You Calculate Equilibrium Partial Pressures in a Chemical Reaction?
The discussion focuses on calculating equilibrium partial pressures for the reaction 2 HI(g) <--> H2(g) + I2(g) at 600 K, where the equilibrium constant (K) is 38.6. The initial pressure of HI is 0.725 atm. The user attempts to set up the equilibrium expression K = [H2][I2]/[HI]^2 and derives a quadratic equation to solve for x, representing the change in pressure. The correct solution involves solving the quadratic equation x^2 - 1.45x - 38.074 = 0, leading to the determination of partial pressures for HI, H2, and I2.
  • Understanding of chemical equilibrium concepts
  • Familiarity with the equilibrium constant expression
  • Ability to solve quadratic equations
  • Knowledge of partial pressure calculations
  • Study the derivation of the equilibrium constant expression for gas-phase reactions
  • Learn how to solve quadratic equations in chemistry contexts
  • Research the concept of partial pressures and their calculations in gas mixtures
  • Explore examples of equilibrium calculations involving different reactions
Chemistry students, educators, and professionals involved in chemical equilibrium analysis and gas-phase reaction calculations.
Xels
At 600 K the equilibrium constant is 38.6 for the reaction
Start with a pressure of 0.725 atm consisting of only HI(g) at 600 K. Calculate the equilibrium
partial pressures of HI, H2 and I2.
K=[C]^n[D]^n/[A]^n
Qp = 0 (shift to the right)
ax^2+bx+c
x=((-b+/-((b^2-4ac)^(1/2)))/(2a))
Given the gas state atm is treated as mol
2HI H2 I2
I .725 0 0
C -2x x x
E .725-x x x
38.6 = (x*x)/(.725-x)^2
38.6 = (x*x)/(x^2-1.45x+.526)
x^2-1.45x-38.074 = 0
x=((1.45+/-((1.45^2-4*1*38.074)^(1/2)))/(2*1))
+x= 5.48
-x = -6.94 (discounted)
I'm either doing it totally wrong or I'm clueless as to where to go from here. I'm assuming I need to find the final pressure of x and then calculate partial pressure using Pa/Pt etc.
Xels said:
C -2x x x
E .725-x x x
Some inconsistency here...
And I have not checked details, but solving
doesn't yield
+x= 5.48
-x = -6.94
I got +/- x by solving (x*x)/(.725-x)^2 quadratically. I'm not sure where to go past this to find partial pressures.
After much reworking I found my error. Thanks for your input Borek.
  • · Replies 19 ·
