How Do You Calculate the Focal Length of a Concave Mirror with a Moving Image?
The discussion revolves around calculating the focal length of a concave mirror based on the position of a light bulb and the movement of its image when the mirror is replaced with a plane mirror. The original poster provides specific measurements and attempts to apply the mirror equation.
  • Participants explore the application of the mirror equation and question the assumptions regarding the signs of object and image distances. There is discussion about whether the image is real and on the same side of the mirror as the object.
Participants are actively questioning the assumptions made in the original poster's calculations, particularly regarding the sign conventions for distances in mirror equations. There is no explicit consensus yet, but several lines of reasoning are being explored.
There is uncertainty regarding the sign convention for the object and image distances, as well as the interpretation of the image movement described in the problem statement. The original poster's understanding of the image's position relative to the mirror is also under scrutiny.
premed_love
A light bulb is placed 10.7 cm in front of a concave mirror. When the concave mirror is replaced by a plane mirror in the same location, the bulb's image moves 4.00 cm closer to the mirror. Calculate the focal length of the concave mirror.
I am given: do: 10.7
and 4.00 is Di
Mirror equation: 1/di+1/do=1/f
I know I have to use the mirror equation so I did. However, I also added 10.7 and 4.00 to get a new di.
1/10.7+1/14.7=1/f
Eventually, I get 6.19 which is wrong! Anyone would like to help me see what is wrong?[/B]
and 4.00 is Di
1/10.7+1/14.7=1/f
Which side of the mirror is the new image? (It's not made clear.)
What's the sign convention for object and image distances when dealing with mirrors?
(What would your equation produce for the flat mirror?)
The only information I am given is the one I have provided. I am told it is a concave mirror- that's it.
In order to write the equation you used, you have to make an assumption about whether the object and image are on the same side of the mirror or on opposite sides. Which did you assume? Is your equation correct for that assumption?
I was thinking the image should be real and on the same side which is why my Di would not be negative.1/10.7+1/14.7=1/f which is why I get
eventually, I get 6.19. Are you trying to imply that my di is negative and my equation should be 1/10.7-1/14.7=1/f
I'm saying it's a strong possibility. Note that the question says
It doesn't say "is 4cm closer" or "moves to 4cm closer and on the opposite side". That suggests to me it moves by 4cm, not by 10.7+14.7=25.4 cm.
So you would think it be a simple mirror equation then: 1/10.7+1/4.0=1/f so 2.94
but 2.94 cm is off. I am so confused!
No, we're discussing what sign is appropriate to use in your original equation. The distances are correct, but are the image and object the same sign or opposite signs?
I think they will be the same size
I think they will be the same sign.
Why?
haruspex said:
Why?
Because it's a concave mirror. The image is also real. Earlier I was thinking they would be different signs as 4.00 cm is moving closer. But then the concave part made me think the sign would be the same.
Read http://en.wikipedia.org/wiki/Curved_mirror#Image_2
