How Do You Calculate the Initial Separation Between Two Charged Particles?
  • Thread starter udontai
    Electricity
20 replies · 5K views · last reply
udontai
One particle has a mass of 3.00 10-3 kg and a charge of +8.00 µC. A second particle has a mass of 6.00 10-3 kg and the same charge. The two particles are initially held in place and then released. The particles fly apart, and when the separation between them is 0.100 m, the speed of the 3.00 10-3 kg particle is 120 m/s. Find the initial separation between the particles.
let the initial separation as r and final separation as d.
kq^2/r^2 = kq^2/d^2 + 1/2m1*V^2 + 1/2m2*V^2
is the the way to solve it? how can i determine the final velocity for the 6x10^-3 particle?
Are their any external forces acting on the system comprising the two charges ?
What is conserved if there are no external forces acting on the system ?
The way you wrote the equation, you can solve it, but you'll get the wrong answer. Is the velocity for particle 1 the same as the velocity for particle 2? No. So why are you using the same variable, V, to represent those two quantities?
If you write the equation properly, you have one equations and two unknowns. You need a second equation if you hope to find specific values of each unknown.
(3.00 10-3 )x 0 + (6.00 10-3 ) x 0 = (3.00 10-3) x 120 - (6.00 10-3 ) x V
i this correct?
Tanya Sharma said:
Yes . Use Conservation of Momentum.
i this correct?
i this correct?
Correct .
There is another problem with this equation apart from what Vela has pointed .
What do these terms represent ?
Tanya Sharma said:
Correct .
as i stated r = initial distance and d= final distance.
Did I ask what r and d represent ?
i saw the r and d is highlighted from my computer screen so i thought you asked about it. lol my bad sorry
But you still haven't answered my question in post#10 .
so instead of kq^2/r^2 = kq^2/d^2 + 1/2m1*V^2 + 1/2m2*V^2.
it should be kq^2/r^2 = kq^2/d^2 + 1/2m1*(V1)^2 + 1/2m2*(V2)^2 as the velocity is different.
right?
No . Sorry but you are not answering the question . I have explicitly remarked that there is another problem with the equation apart from what Vela has pointed .
Please explain what do terms I marked in red in post#10 represent ?
kq^2/r2 represent the electrostatic force between the two charges
This is wrong .
How can you have force in conservation of energy equation ?
Instead of electrostatic force you need to have electrostatic potential energy of the two charges .
Tanya Sharma said:
This is wrong .
V = kq/r ?
udontai said:
V = kq/r ?
No .
Please look up in your notes or book or on the web .
