How Do You Calculate the Speed of a Rod in a Magnetic Field?
The discussion revolves around calculating the speed of a rod in a magnetic field, specifically focusing on a scenario where a rod carries a current and rolls along parallel rails in the presence of a magnetic field. The original poster presents a problem involving a rod's mass, dimensions, current, and magnetic field strength, seeking clarification on their calculations and the correct application of energy and work principles.
  • Participants discuss using work and energy equations to find the rod's speed, questioning the validity of their approaches and the interpretation of the energy terms involved. There are inquiries about the meaning of variables in the equations and whether rotational kinetic energy should be included in the calculations.
Participants are actively engaging in clarifying concepts related to energy conservation and the work-energy theorem. Some have suggested that the original poster may need to reconsider how they are applying the equations, particularly regarding the inclusion of rotational kinetic energy. There is a recognition of the need for more detail in the original poster's attempts to identify potential mistakes.
There are ongoing discussions about the correct formulas for moment of inertia and the conditions under which certain energy equations can be applied. Participants are also addressing the potential confusion surrounding the interpretation of magnetic field energy and the relationship between linear and rotational motion.
SHOORY
A rod of mass 0.720 kg and radius 6.00 cm rests on two parallel rails that are d=12.0 cm apart and L=45.0 cm long. The rod carries a current of I=48.0 A in a direction that makes it rolls along the rails without slipping. A uniform magnetic field of magnitude 0.240 T is directed perpendicular to the rod and the rails. If it starts from rest, what is the speed of the rod as it leaves the rails?
the answer is 1.07m/s
but I keep on getting wrong answers and I don't know what is the mistake
I used both
Energy and work equation
equations of moving in one dimension
but it didn't work
so how to get the right answer
and what is the mistake in using energy and equations of moving in one dimension
[/B]
We ask that you please fill out all three sections of the template in the future.
Using work and energy is a good way to approach the problem. Without seeing more details of your attempt, we cannot tell where you made a mistake.
E
Ei=Ef
there is no magnetic fied in the end and its at rest in the beginning so
I A B = 0.5 m v^2
v=(2IAB/m)^0.5
then the answer is wrong
SHOORY said:
Ei=Ef
I A B = 0.5 m v^2
What does "A" represent? What type of energy is represented by I A B?
Also, does 0.5 m v^2 include the rotational energy associated with rolling?
ENERGY OF MAGNETIC FIELD IS
I A B
WHERE I is the current
A is the cross-sectional area
B is the magnetic field
I A B
I've never seen the formula I A B for "magnetic field energy". However, it is possible to show that I A B is the work done by the magnetic force on the rod if A denotes the distance between the rails multiplied by the distance the rod travels. I would think that you would need to show how you arrive at the expression I A B for magnetic field energy, unless this was already derived in your class or textbook.
A is pi r^2 of the rod
Hmm. If A is ##\pi r^2## of the rod, then I don't think I A B can be interpreted as the initial energy Ei of the system. Instead, you can use the work-energy theorem: the net work done on the rod equals the change in KE of the rod. For the KE, you will need to take into account that the rod rolls without slipping.
what made you think we can't use it if we can't use it now when can we use it is there any conditions of using it
so if we used the work equation it will be
I L B d = 0.5mv^2
when we use the work equation we get v=1.314m/s and the answer is 1.07 so i really need to know the conditions of using work and energy
Sorry, I'm not following what you said here. Where have you seen the formula I A B for magnetic field energy?
I L B d = 0.5mv^2
The left side is good for the work done by the magnetic force. The right side does not represent the total KE of the rod. The rod rotates about its central axis as it rolls without slipping. So, there is an additional KE associated with this rotation.
and what is that KE equal to
do you mean angular velocity or something
sorry but its the first time I hear about an additional kinetic energy for rolling
See the bottom of the page at this link: http://hyperphysics.phy-astr.gsu.edu/hbase/rotwe.html
SHOORY said:
I=md^2/12
This is not the correct expression for the moment of inertia of a cylinder that rotates about its central axis. You’ve used the formula for the moment of inertia about a different axis and for a thin rod.
w
TSny said:
This is not the correct expression for the moment of inertia of a cylinder that rotates about its central axis. You’ve used the formula for the moment of inertia about a different axis.
what is it
if it is md^2/3 it is still a wrong answer
if it was md^2/2 it is still wrong
ohhhhh okay i got it
it is 1.07 my mistake
thanksssssssssssssssss thanks thanks
SHOORY said:
w
what is it
That’s not the correct formula either. Be sure you are clear on the orientation of the axis of rotation.
is it F=IqI v B
or
F=q v B
there are questions when you solve them you get a positive magnetic field but when you check your answer it is negative why
does it have anything to do with either its a proton or electron
OK, good.
can you solve this please
An electron has an initial velocity of (12 j + 15 k) km/s and a constant acceleration of 2*10^12 i m/s^2 in a region in which uniform electric and magnetic fields are present. If B= (400*10^-6 i) T, find the electric field.
I SOLVED IT AND FOUND Ex Ey Ez but all of them was positive when i checked just Ez was positive
It would be best to start a new thread with a new title for this one. (But it looks like your mistake might be the same sign error that @BvU is pointing out in a similar thread.)
