How Do You Calculate Total Resistance in a Complex Circuit?
  • Thread starter Thread starter VisualStudio
    Network
12 replies · 3K views
VisualStudio
In the above diagram, calculate the total resistance between A and C
R1 = R2 = R3 = R5 = 3.3 Ω
R4 = R7 = R8 = 6.6 Ω
R6 = R9 = R10 = 2.4 Ω
Sum/Product
Can anyone give me an insight on where to start for this?
So my current guess is that, R8+R10 = Parallel, meaning that then becomes in series with R9, I really don't know where to start with this
Sum/Product
Welcome to the PF.
I don't see a lot of simplifications in the circuit. Just write the KCL equations and solve. Put a 1V source between A and C, and see how much current you get. :-)
Hi, the question is to calculate the total resistance, therefore we don't need to put in a correct source, correct?
But that network is complicated enough that I don't see easy ways to use series & parallel combinations to collapse the network down to a resistor between A & C. Instead, just put an imaginary 1V voltage source between A & C, and calculate the node voltages and currents. That is one way to figure out the equivalent resistance.
R8 and R10 aren't in parallel. R9 and R10 are, but their combination isn't in series with anything else. There are two other pairs in parallel as well. Note also that R1 is shorted.
If you know the delta-wye transformation, you could use that, but Berkeman's suggestion is probably easiest once you simplify the circuit as much as you can.
Ok thanks for your help, i'll be having another crack at it tomorrow. So what is exactly in series and parallel please?
So do you think it's wise that I add a voltage source to this circuit? And where would i place it?
Sorry for the late reply, I think delta star transformation would be the way about it. Where would I start with this?
Could anyone help me with this?
First make all the parallel resistance simplifications that are available. Pay attention to what R1 is connected to.
Then identify an obvious candidate for Y to Delta transformation to generate more parallel resistor opportunities.
You can use series and parallel resistors until you get a network with 5 resistors where this does not work any more (plus one resistor that can be treated separately).
That smaller network will need a Delta/Y transformation or Kirchhoff's laws, but start with the easier steps first.
