How Do You Convert CO2 PPMV in Air to PPMW in Water?
  • Context: Graduate
  • Thread starter Thread starter alwayslearning
    Co2 Measuring Water
This discussion focuses on converting CO2 concentration from parts per million by volume (ppmv) in air to parts per million by weight (ppmw) in water. The user is developing a device to measure dissolved CO2 in water and seeks to understand the relationship between these two measurements. Key tools mentioned include a CO2 air sensor and a temperature sensor, with the Krichevsky-Kasarnovsky Equation and Henry's Law being critical for the conversion process. The user successfully applied these concepts to achieve a better understanding of the measurements involved.
  • Understanding of Henry's Law
  • Familiarity with the Krichevsky-Kasarnovsky Equation
  • Basic knowledge of CO2 sensors and microcontroller integration
  • Temperature correction methods in gas solubility measurements
  • Research the Krichevsky-Kasarnovsky Equation in detail
  • Study Henry's Law and its applications in gas solubility
  • Learn about CO2 sensor calibration and data interpretation
  • Explore temperature correction techniques for gas solubility in liquids
Environmental scientists, engineers developing gas measurement devices, and anyone involved in water quality testing and CO2 solubility research.
alwayslearning
Measuring CO2
I have been searching for an answer to this for quite a while, so I'm hoping somebody here can help me out. I've spent quite a bit of time digging and reading, and I've found plenty of information, but I'm not always sure what to make of it. I am working on making myself a small electronic device to measure the dissolved CO2 in water in ppm by weight.
I'm going to make a small sealed chamber that will have an opening only to the water (but not to the atmosphere). The CO2 will off gas into the chamber until the concentration of CO2 in chamber becomes at equilibrium with the concentration in the water. I know that some of the CO2 will be converted into carbonic acid, but as I understand it, the majority of it will remain as CO2, and for the precision I'm going for I think I can just ignore that.
I'm going to place a small CO2 air sensor in the chamber that I will connect to a micro controller. The CO2 sensor reads concentration in ppmv. I'll also put a temperature sensor in there since I'm pretty sure I'll need to correct for temperature.
The problem I'm having is taking the ppm by volume and equating it to the concentration of CO2 in water, which needs to be reported in ppm by weight. I can't find a formula to do the conversion, and it's been so long since I took physics (I'm 37), so I'm completely unable to figure this out at this point.
Basically, I'm trying to figure out if it's V ppmv in the chamber, than what's the W ppmw in the water. Anybody have any ideas on how you'd calculate this?
Google for Henry's law, and more specific, for Krichevsky-Kasarnovsky Equation, modeling the system CO2-H2O
What's funny is that when I read your comment my first thought was "of course I've already read that, why else would I be here?" Except I hadn't read into Krichevsky-Kasarnovsky Equation, so I went off and did that first. The part that was missing for me was the weight in water to volume in air relationship. In my search I found a document on the Krichevsky-Kasarnovsky Equation that explained this clearly. From there I went back to the parts I needed from Henry's law, which made more sense to me, and I was able to figure it out — even correcting for temperature!
So, thank you for your very simple answer! It was better than just getting a formula, because now I actually understand what the numbers mean.
15K
