How Do You Deal With Unsolvable Problems?
  • Thread starter Thread starter Lancelot59
The discussion revolves around the challenges of tackling difficult chemistry assignments, particularly when help is unavailable. A user expresses frustration after spending an entire weekend on two problems, feeling a sense of failure due to an inability to solve them before the deadline. Other participants share strategies for dealing with difficult problems, emphasizing the importance of starting assignments early and seeking help from professors as soon as possible. One user highlights the necessity of understanding the problem's requirements, noting that certain questions may lack sufficient information to solve. The conversation also touches on the reality of facing unsolvable problems in real-world scenarios and the value of conducting background research and collaborating with knowledgeable peers to find potential solutions. Overall, the key takeaway is the importance of proactive engagement with assignments and the acceptance of occasional setbacks in the learning process.
Lancelot59
Well after the first initial panic at the start of the semester I've calmed down and settled into a pile of what I think so far is fail.
Take this last weekend for instance. I spent the whole weekend trying to solve TWO problems from a chemistry assignment. Unfortunately nobody on the forums go to it, but that's not the issue. How do you guys deal with things you have no clue how to solve, and can't get any help on?
Said assignment is due first thing in the morning for marks. I probably won't be able to get help from my prof to get them solved, and there's just a feeling of failure over these. I should be able to do them using what I know, but I can't.
Let it go. Plus you probably want to start doing homework earlier then the weekend its due haha.
Which one? The Beer's Law problem or the combustion problem? There are already 12 postings on the Beer's Law one.
Lancelot59, I just read your combustion analysis gas problem and gave a comment there. Although I am no longer skillful with gas problem exercises, the problem description is missing too much information. Based on this, you apparently correctly called it an unsolvable problem. The description needs enough information to determine initial conditions and final conditions.
Oh, the beers law one I managed to solve with Borek bouncing things at me till the light went on.
@Pengwuino: I always try to start on stuff as soon as I can. This week however was a bit packed. I had actually started on it, but I hadn't reached those questions before the weekend.
The thing that really gets me down is that I'll be losing marks for these two problems.
Yah you should just let it go until you can get help from a professor, even if you lose points. It happens, no one's perfect. One tip I would say is to look over every problem you get as soon as you get it so you can ask professors for some insight (after doing a little work on any problems that look hard) into the problems before they are unaccessable.
Trust me i had the same problem. What i do know is always ask the teacher for help and always do my homework cause math, phyiscs and chem are all subjects were you need to know the previous work to continue.
Good Luck.
Lancelot59 said:
<snip>
<snip>
Sounds like the real-world. Unsolved problems are the only ones someone will pay you to work on. Notice I said "work on", not solve.
Personally, I do as much background research as possible (previous attempts to solve the problem) and then start talking to people who know more than I. That helps weed out the obvious dead-ends, and highlight a couple promising approaches. Then I just jump in. Hopefully, I can make some progress (or figure out how to make some progress). But it's also good to know when to quit and move on to something else.
