How Do You Determine Superman's Initial Velocity in a 2D Momentum Problem?
26 replies · 3K views
Walter White
Question is on the attachment photo.
I tried to create an equation but I didn't know the momentum for each of the people in the scenario because none of them have a given speed.[/B]
I just need the velocity of Superman to solve the problem. How do we find the speed?[/B]
How far will Lois have fallen when she is caught?
It has to be the difference between the 2 heights. 13.2 - 6.8.
So what is Lois' velocity when they meet?
Walter White said:
I don't know, I need time to figure that out
When you say you need time, do you mean you think you need to know how much time elapsed, or merely that you cannot work it out immediately?
Like I need the time to figure out the velocity from the formula d/t
Yes how much time was elapsed because there's no mention of time in the problem
For motion under constant acceleration, there are five standard variables (usually known as SUVAT, s for displacement, u for initial speed, v for final speed, a for acceleration, t for time). There are correspondingly five equations. Each equation omits one of the five variables. Are you familiar with these?
Oh wait, Lois is falling with gravity, so we know acceleration. Now I can figure out time
I'll try to figure it out and get back to you thanks
Right. I suggest you Google SUVAT. Plenty of references. Or, in this case, you can use work conservation.
Oh, and you do not need to find the time. You can get the speed directly.
Hi, I got 16.1 m/s for Lois velocity. How do I find superman's initial velocity?
Stick with vertical motion for now. You know the vertical speed of each just before they meet. Can you find their vertical speed just afterwards?
Hi again. I tried my best to solve it but I'm not getting the right answer. Can you possibly give it a shot yourself? Or just tell me another hint on how to solve it. Thanks
Please post your working.
Then I found superman's velocity using the time for Louiss to reach down to Superman and the length of the pit
Then I put it into a momentum equation initial and final, solved for vx and vy and total velocity
Walter White said:
Then I put it into a momentum equation initial and final, solved for vx and vy and total velocityView attachment 106222
I cannot follow what you did there, not only because it was upside down and hard to read. (The posting of images is intended for diagrams and textbook extracts. Please take the trouble to type in your working. This makes it both easier to read and easier to make specific comments on.)
What is going on in that first line? Why are you multiplying Superman's mass by 9.8 in a line titled X:?
In which line are you applying conservation of vertical momentum?
By the way, in calculating Lois' vertical speed you had a negative value inside the square root, so you just ignored the minus sign. To be consistent with 'positive up' you should have set Lois' displacement as -6.4m. Then you would have had a positive value to square root.
9.8 is superman's velocity. I'm multiplying it by his mass because I want the momentum of Superman. The line is titled x because this is 2d momentum and we need both x and y to get final velocity of x and final velocity of y
No, Superman's initial velocity is what you have to find. I see no 9.8m/s in the question statement.
