How do you differentiate implicitly with three variables (x,y,a)?
The discussion revolves around finding the equation of the tangent line to the curve defined by x^(2/3) + y^(2/3) = a^(2/3) at the point (a, 0). The main challenge is differentiating implicitly with three variables, specifically dealing with da/dx. Initially, there was confusion about treating 'a' as a constant versus a variable, which led to difficulties in calculating dy/dx. Clarification was provided that since 'a' is a constant in this context, da/dx equals zero, simplifying the differentiation process. Ultimately, the user resolved their issue by ensuring positive exponents were used in their calculations.
Antebellum
Find the equation of the tangent line to the following curve at the indicated point:
x^(2/3) + y^(2/3) = a^(2/3) at (a, 0)
Power rule
Chain rule
(2/3)x^(-1/3) + [(2/3)y^(-1/3)](dy/dx) = [(2/3)a^(-1/3)](da/dx)
Okay, from here I am stuck. I have no problem doing implicit differentiation when the only variables are x and y, but I have no idea what to do with that da/dx. The problem didn't tell me to treat a as a constant, so I assume I have to treat it as a variable (and when I tried treating it as a constant, I ended up solving for dy/dx and got 0 on the bottom, so it won't work anyways). I'm also a little confused about finding the derivative at (a, 0)... if a is not supposed to be a constant, how does this work?
Basically, how do I find the derivative here when I have da/dx to worry about as well as dy/dx? Scratching my head. I don't even know where to begin.
Any help would be MUCH appreciated! Thank you!
a is obviously a constant, so da/dx = 0. Check your arithmetic; I think you will get 0 in the numerator, not the denominator if you express the answer with positive exponents.
But there is a catch to this problem. Plot the graph using, for example, a = 1.
Thank you so much, LCKurtz! My problem was that I didn't express the derivative with positive exponents. I have the right answer now. Thanks! :D
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 25 ·
  • · Replies 24 ·
