How do you evaluate the integral of cotangent squared from Pi/4 to Pi/8?
  • Thread starter Thread starter Briggs
    Integral
The discussion focuses on evaluating the integral of cotangent squared from Pi/4 to Pi/8. Participants suggest using the identity cot(2x) = cos(2x)/sin(2x) to express the integral as the ratio of cosine squared to sine squared. There is a correction regarding the limits of integration, which should be from Pi/8 to Pi/4. The conversation emphasizes the need to apply trigonometric identities to simplify the integral, particularly using the Pythagorean identity to split the integral into two parts. The overall approach highlights the importance of proper substitution and manipulation of trigonometric functions in integral calculus.
Briggs
I have the question Evaluate \int_{Pi/4}^{Pi/8}_cot^2{2x}dx
So integrating this should (I hope) give [\frac{-1}{2}cot{2x}-x] for those limits.
But I have never evaluated the cot integral before, I know that cotx=1/tanx. Do I substitute this identity in and work from there?
You could but I suspect that \frac{1}{tan^2 x} would not be easy to integrate. How about just cot(2x)= \frac{cos 2x}{sin 2x}?
\int_{\pi/4}^{\pi/8}cot^2(2x)dx= \int_{\pi/4}^{\pi/8}\frac{cos^2(2x)}{sin^2(2x)}dx.
Since those are even powers you will need to use trig indentities to reduce them. By the way is there a reason for integrating from a larger value of x to a smaller?
Ah that was a mistake, the x values should be the other way around.
So would \int_{\pi/8}^{\pi/4}cot^2(2x)dx= \int_{\pi/8}^{\pi/4}\frac{cos^2(2x)}{sin^2(2x)}dx integrate to \frac{\frac{1}{2}sin^2(2x)}{\frac{-1}{2}cos^2(2x)} ? Which I assume would simplify to -tan^2_(2x)
Unfortunately not, but use the fact that \cos ^2 \alpha + \sin ^2 \alpha = 1 on:
\int {\frac{{\cos ^2 \left( {2x} \right)}}{{\sin ^2 \left( {2x} \right)}}dx} = \int {\frac{{1 - \sin ^2 \left( {2x} \right)}}{{\sin ^2 \left( {2x} \right)}}dx}
Then split the integral in two.
