How do you find the Impulse Response, h(t)
The discussion revolves around finding the impulse response, h(t), given specific input and output functions in a systems context. Participants explore various methods, including convolution and derivatives, while addressing the challenges of the problem without having covered the Laplace transform yet.
  • Homework-related
  • One participant suggests dividing y(t) by 8t to simplify the problem, but expresses uncertainty about the correctness of this approach.
  • Another participant points out that the convolution equation should be f(t) * h(t) = y(t), correcting an earlier misstatement.
  • Several participants discuss the relationship between the input, output, and impulse response, with one mentioning theorems related to derivatives of responses to different inputs.
  • Concerns are raised about the clarity of the problem statement, particularly regarding the definition of f(t) as the system input.
  • One participant expresses confusion about using integrals to find h(t) without knowing its form, questioning how to proceed with the given information.
  • Another participant suggests differentiating the output twice to find the impulse response, emphasizing the need to apply the product rule due to the presence of the unit step function.
  • There are expressions of frustration and confusion regarding the mathematical processes involved, with one participant indicating a struggle with understanding the convolution integral.
Participants do not reach a consensus on the best approach to find h(t). Multiple competing views and methods are presented, with ongoing uncertainty about the correct application of mathematical techniques.
Participants note limitations in their current understanding, particularly regarding the Laplace transform, which has not yet been covered in their course. This affects their ability to fully engage with the problem as presented.
This discussion may be useful for students studying systems and signals, particularly those grappling with convolution and impulse response concepts in the context of their coursework.
martnll2
How do i find the impulse response, h(t), given the following?
f(t) = 8t u(t)
y(t) = (-2e^-2t + 8e^-t + 4t - 6) u(t)
f(t) convolved with y(t) = h(t)
I thought that you divide out y(t) by 8t to make f(t) = u(t) then take the derivative of the modified y(t) expression, call it g(t) in order to get h(t) but the derivatives look nasty and I don't think it is right.
Do you know about the Laplace transform? What is the relationship between input, output, and the impulse response in that domain?
We didn't cover Laplace yet, that comes next week. Is there an alternate way to solve this?
I don't think so. And I think your relevant equation is wrong:
"f(t) convolved with y(t) = h(t)"
It should be f(t) * h(t) = y(t) where * is the convolution operator
You are correct. I did mess that one up.
f(t) = 8t u(t)
I realize somewhat belatedly that the problem is poorly described. What is f(t)? Is it the system input? It's customary to call the input x(t).
We know δ(t) = du/dt ... I already tried dividing both sides by 8t, and taking the derivative, but it didn't seem to work. Here is my work.
f(t) = 8t u(t)
y(t) = [-2e^(-2t) + 8e^(-t) + 4t -6] u(t)
Is it right to change f(t) = u(t) and y(t) = g (t) = {[-2e^(-2t) + 8e^(-t) + 4t -6] u(t)} / 8t
then h(t) = dg/dt?
I tried this but got unreal coefficients for the impulse term.
The reason I'm showing you this is in an intro course to systems, this should be a plain fact stated in the book (It was in mine, and rude man's comment got my memory jogging). I doubt the problem expected you to derive this, and the real culprit is you most likely not reading your book.
We have (leaving off 8)
y(t) = \int\limits_{-\infty}^{\infty} h(\tau)f(t-\tau)d\tau
y(t) = \int\limits_{-\infty}^{\infty} h(\tau)(t-\tau)u(t-\tau)d\tau
y(t) = t\int\limits_{-\infty}^{\infty} h(\tau)u(t-\tau)d\tau-\int\limits_{-\infty}^{\infty} h(\tau)\tau u(t-\tau)d\tau
y(t) = t\int\limits_{-\infty}^{t} h(\tau)d\tau-\int\limits_{-\infty}^{t} h(\tau)\tau d\tau
tau is just a dummy variable so these are straight integrations.We know h(t) is zero when t < 0:
y(t) = t\int\limits_{0}^{t} h(\tau)d\tau-\int\limits_{0}^{t} h(\tau)\tau d\tau
But that looks a whole lot like integration by parts of
\int\limits_{0}^{t}\int\limits_{0}^{t}h(\tau)d \tau d \tau
In general, if an excitation is changed to its integral, the response also changes to the integral of the previous response. Since you will be encountering this, I'll go ahead and remind you that you have to use product rule with u(t) being one function and the other stuff being another to find the right answer.
f(t) = 8t u(t)
then h(t) = dg/dt?
Theorem:
If y(t) is the reponse to a ramp, then
y'(t) is the response to a step input, and
y''(t) is the response to an impulse input (Dirac delta function).
I can't give you the proof of this since you haven't had the Laplace transform.
The problem is easy after that.
rude man said:
Theorem:
You can do it in the time domain.
y_1(t) = \int\limits_{-\infty}^{\infty}h(\tau)f(t-\tau)d\tau
y_2(t) = \int\limits_{-\infty}^{\infty}h(\tau)f&#039;(t-\tau)d\tau
Just by looking at this, it is clear that y_2(t) is the derivative with respect to time of y_1(t) since f is the only part that depends on time.
I know what you say is right - has to be - but the math still eludes me. Never was too comfortable with the t's and tau's in the convolution integral, even when I had to know it.
So thanks for your contribution & the OP should have no more trouble with getting the solution.
I'm still confused. I don't know how you could use these integrals not knowing h(t) since the problem is asking to find h(t).
f(t) is the input signal, y(t) is the output signal. These are both given, and i know that y(t) = \int h(\tau)f(t-\tau) d\tau from -∞ to ∞. I don't know how to use these facts to solve h(t)
Do I just take the derivative with respect to tau on both sides and solve h(t) that way?
What RoshanBBQ said in his last post is equivalent to what I said in my last post.
I suggest you look carefully at my last post ... then, if you're not happy with my lack of proof, study RoshanBBQ's last post which essentially proves in the time domain what I would have demonstrated in the frequency domain, except apparently you haven't been exposed to the frequency domain yet.
As I said, I myself get a bit nervous with these convolution integrals. But it's the only way if you insist on a proof and are restricted to the time domain.
The ramp is the double integral of the impulse. So the ramp response is the double integral of the impulse response (as I showed in post 8). Differentiate your output twice to find the impulse response (with respect to time). Keep in mind to use product rule with u(t) being one function and (-2e^-2t + 8e^-t + 4t - 6) being another function for the first derivative. You will have to use product rule for the second derivative too. Then divide what you get by eight for the final answer. Finally, you can check yourself by doing the convolution integral with the input to recompute the output.
Are you not reading your textbook?
Yeah... I do read my textbook. I guess this is one of the main reasons I am changing my major; I can't comprehend anything! I need to see the professor tomorrow.
  • · Replies 17 ·
