How do you find the normal force of an object being pushed?
The discussion revolves around determining the normal force acting on a wagon being pushed at an angle, with specific parameters including mass, applied force, and coefficient of kinetic friction. Participants are exploring the forces involved in this scenario.
  • Participants discuss the forces acting on the wagon, including gravity, friction, and the applied force. There is uncertainty about the correct equations to use for calculating the normal force and acceleration.
Some participants are attempting to clarify the forces at play and the relationships between them. Guidance has been offered regarding the setup of equations for vertical and horizontal forces, but no consensus has been reached on the specific calculations.
There is mention of potential confusion regarding the coefficient of kinetic friction and its implications for the problem setup. Participants are also questioning the direction of the applied force in relation to the wagon.
Maya KDeoimmich
A 42 kg wagon is being pushed with a metal rod that makes an angle of 46 with the horizontal. The applied force is 449 N and the coefficient of kinetic friction between the wagon and the ground is 0.21.
I'm not sure what equation to use to find the normal force and then the acceleration. Thanks!
Fy = mgcos46-N
You'll use Newton's laws, of course.
First step: What forces act on the wagon? (I count three forces.)
Ok thanks but can you please walk me through the steps of how to find the normal force and the acceleration
First answer my question. What forces act on the wagon?
Gravity, friction, and the applied force
Oops, one more force acts. (I meant to say four, not three.) But those three are good. What's missing?
normal force? not sure
Exactly.
Now you'll set up two equations: One for vertical forces (vertical components) and another for horizontal forces.
Hint: What must the sum of the vertical forces equal?
Which way? I.e. is it tending to push down on the wagon or up on it?
Fy = mgcos46-N
How do you get that? Isn't the mg vertical?
Ouch! Unless the wheels are locked they mean rolling resistance, not friction, but don't worry about that for now.
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 18 ·
