How do you integrate a square wave?
To integrate a square wave in an op-amp integrator circuit, the function representation involves using the equation V_out(t) = (-1/RC) ∫ V_in(t) dt, where V_in is the square wave input. The integration should be performed in sections over specific intervals, accounting for initial conditions, as the square wave is a discontinuous function. Each half cycle of the square wave results in a linear output, leading to a triangle wave output. One participant calculated the output for a 2V peak square wave at a frequency of 2000 kHz, resulting in a triangle wave equation valid for each 500 µs interval. This approach effectively demonstrates how to handle the integration of a square wave signal.
Evilinside
I'm doing homework where i have to find a function representation of the output signal from a simple op amp integrator circuit with a 4.7k resistor and a .01uf capacitor. I know I'm supposed to use the equation -1/rc * int vin(t) but the input is a square wave signal. I never learned how to integrate that. Can i anyone help me out? Do i have to use something called a Fourier series or Fourier transform?
This quote from wikipedia also applies to a square wave:
A definite integral of a function can be represented as the signed area of the region bounded by its graph.
http://upload.wikimedia.org/wikipedia/commons/9/9f/Integral_example.svg
Does that help?
This is a discontinuous function, so it is easier to integrate in sections. You need to do integrals over specifc intervals and you need to account for the initial conditions at each interval.
As pointed out above, you have to integrate each half cycle of the input square wave in sections. The basic form of the integration is
V_{out}(t)=\frac{-1}{RC}\int_t V_{in}(t) dt
Each segment is a straight line. The line is continuous, but its derivative is not. The output of the square wave is a triangle wave.
Bob S
Yes I finally got the answer i think. I set the square wave input to 2V peak and i got an answer of (-4Vp/.000047)*t and since the frequency of the input square wave is 2000khz, the period is 500us. so (-4v/.00047)*t should be the graph of a triangle wave for the an interval of 0-500us and repeat itself every period after that. I think that's the answer anyway. Oh well whether I'm wrong or right, thanks for help.
  • · Replies 29 ·
11K
