How do you know if a particle is an electron/proton?
  • Thread starter Thread starter help908
    Particle
To determine if a particle is an electron or a proton, measuring its charge or mass is essential. Protons move in the direction of electric field lines, while electrons move in the opposite direction when subjected to an electric field. The right-hand rule can be applied in magnetic fields to differentiate between the two. Additionally, protons have a positive charge and greater mass compared to electrons, which have a negative charge. These methods provide clear identification of the particles in question.
help908
im sure its a simple question but i don't know thanks
If you know it's either a proton or an electron (but no other kind of particle), then all you need to do is measure its charge, or its mass.
- Warren
Hmm.. as a real life experiment?
Magnetic fields and electric fields can do this very easily.
If you apply an electric field, a proton will go in the direction of electric field lines, and an electron will go the reverse.
Magnetic fields: right hand rule.
Otherwise, chroot is right. Electrons have negative charge. Protons have positive. A proton weighs more than an electron.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
