How do you konw if dipole movement is negative or positive?
The discussion centers on determining the dipole moment of a system with two charges, +2C and -2C, separated by 2 meters. The dipole moment is calculated using the formula p = qL, where p is the dipole moment, q is the magnitude of the charge, and L is the distance between the charges. Participants confirm that the value of q used in the formula should always be the positive magnitude of the charge, which in this case is 2C.
  • Understanding of electric charge and its properties
  • Familiarity with the concept of dipole moment
  • Knowledge of the formula p = qL
  • Basic grasp of electrostatics and charge interactions
  • Study the derivation and applications of the dipole moment in electrostatics
  • Learn about the behavior of electric fields generated by dipoles
  • Explore the concept of electric potential due to dipoles
  • Investigate the role of dipole moments in molecular chemistry
Students of physics, educators teaching electrostatics, and professionals in fields involving electric charge interactions and molecular chemistry.
pyroknife
Let's say you have 2 charges of magnitude 2C except 1 is + and the other -. They're separated by 2m. dipole moment=p=qL
Which q do you plug in there?
The formula you quote is for a dipole consisting of two charges: +q and -q. Therefore, you plug in the magnitude of the charges q, which is positive by definition.
  • · Replies 25 ·
  • · Replies 18 ·
