How Do You Prove the Schwarz Inequality?
  • Thread starter Thread starter IHateMayonnaise
    Inequality
4 replies · 3K views
IHateMayonnaise
Prove the schwarz inequality:
[tex]|<\alpha|\beta>|^2\leq<\alpha|\alpha><\beta|\beta>[/tex]
[tex]<\alpha|\alpha>\geq 0[/tex]
[tex]|\alpha>=|\beta>-\left(\frac{<\alpha|\beta>}{<\alpha|\alpha>}\right )|\alpha>[/tex]
The first step would obviously be to evaluate the first equation using the second:
[tex]<\alpha|\alpha>=\left <|\beta>-\left(\frac{<\alpha|\beta>}{<\alpha|\alpha>}\right )|\alpha>\middle | |\beta>-\left(\frac{<\alpha|\beta>}{<\alpha|\alpha>}\right )|\alpha>\right>[/tex]
..And from here I am kind of stumped. I am familiar with the identity [tex]<a+b|c>=<a|c>+<b|c>[/tex], however what would the identity be for [tex]<a+b|a+b>[/tex]? Am I even going in the right direction here?
In Shanker's Principles of Quantum Mechanics 2nd ed. Pg 17, it says that the next step is:
[tex]=<\beta|\beta>-\frac{<\alpha|\beta><\beta|\alpha>}{<\alpha|\alpha>}-\frac{<\alpha|\beta>^*<\alpha|\beta>}{<\alpha|\alpha>}[/tex]
I am not understanding this logic. I know that [tex]<\alpha|\beta>[/tex] represents the inner product of [tex]\alpha[/tex] and [tex]\beta[/tex], respectfully, but I do not understand how he gets to that step.
For a start I don't understand your second relevant equation; you've got alpha on both sides. Are you choosing a beta (resp. alpha) such that that equation holds for each given alpha (resp. beta)?
I think you want to define a new quantity [tex]|\gamma \rangle[/tex]:
[tex]|\gamma \rangle=|\beta \rangle-\left(\frac{\langle \alpha|\beta \rangle}{\langle \alpha|\alpha \rangle}\right )|\alpha \rangle[/tex].
Now we want to take the adjoint; that is essentially replace all bras with kets and all complex numbers with their complex conjugates: some examples
If
[tex]|\gamma \rangle = i |\alpha \rangle[/tex]
then
[tex]\langle \gamma | = -i \langle \alpha |[/tex]
Or If
[tex]|\gamma \rangle = \langle \alpha | \beta \rangle |\alpha \rangle[/tex]
then
[tex]\langle \gamma | = \langle \beta | \alpha \rangle \langle \alpha |[/tex]
(Why? Remember changing the order of the inner product gives the complex conjugate).
Your linearity equations are right. You should be able to follow Shankar if you rewrite the equation for [tex]\langle \gamma | \gamma \rangle[/tex] correctly.
Thanks for the reply fantispug!
Yes; I apologize I meant for that to be gamma instead of alpha. So are you staying I should take the adjoint of the new quantity, or the adjoint of the inner product of the new quantity with itself?
Also: did you mean:
[tex]|\gamma \rangle =i|\gamma \rangle[/tex]
instead of
So if I rewrite what I had in my original post with gamma instead of alpha, we have:
[tex] \langle \gamma|\gamma \rangle=\left < |\beta \rangle-\left(\frac{\langle\alpha|\beta\rangle}{\langle\alpha|\alpha\rangle}\right )|\alpha\rangle\middle | |\beta\rangle-\left(\frac{\langle\alpha|\beta\rangle}{\langle\alpha|\alpha\rangle}\right )|\alpha\rangle\right>[/tex]
And taking the adjoint (I think I am doing this right):[tex] \langle \gamma|\gamma \rangle=\left < \langle\beta|^*-\left(\frac{\langle\beta|\alpha\rangle}{\langle\alpha|\alpha\rangle}\right )\langle\alpha|\middle | \langle\beta|^*-\left(\frac{\langle\beta|\alpha\rangle}{\langle\alpha|\alpha\rangle}\right )\langle\alpha|\right>[/tex]
I'm pretty sure he meant take the adjoint of the Ket [itex]\vert\gamma\rangle[/itex], in order to obtain the Bra [itex]\langle\gamma\vert[/itex], since (as you should have learned)
[tex]\vert\gamma\rangle^\dagger=\langle\gamma\vert[/tex]
for any Ket [itex]\vert\gamma\rangle[/itex]
Also: did you mean:
instead of
Again, I'm pretty sure he meant exactly what he posted...he is simply providing an example for the ket defined by the equation [itex]|\gamma \rangle \equiv i |\alpha \rangle[/itex] (this is a different gamma than the one you will use in your problem, it is just an example to demonstrate how to turn kets into bras)
For this example,
[tex]\langle\gamma\vert=\vert\gamma\rangle^\dagger=\left(i\vert\alpha\rangle\right)^\dagger=-i\langle\alpha\vert[/tex]
No, if [itex]|\gamma \rangle=|\beta \rangle-\left(\frac{\langle \alpha|\beta \rangle}{\langle \alpha|\alpha \rangle}\right )|\alpha \rangle[/itex]. then
[tex]\langle\gamma\vert=|\gamma \rangle^\dagger=\left(|\beta \rangle-\left(\frac{\langle \alpha|\beta \rangle}{\langle \alpha|\alpha \rangle}\right )|\alpha \rangle \right)^\dagger[/tex]
