- 50,420
- 26,462
As I said in the parenthetical note in the last part of what you quoted from my post.cianfa72 said:note that observers A and B, supposed to be at rest in the same inertial frame, share the same "now" sets in spacetime
I am assuming this is in response to one of my latest posts about the distance between A and B in figure 1 (A, B perspective) and the distance between A and B in figure 4 (C's perspective), but I don't think I said the spatial separation effected their "now". Does something I said make that indirectly true?cianfa72 said:I'm late for the OP question, but note that observers A and B, supposed to be at rest in the same inertial frame, share the same "now" sets in spacetime.
Ibix said:Here are a few spacetime diagrams. If you haven't come across them, they're simply plots of the position of an object over time, the custom being that time goes up the page. So a vertical line represents an object that isn't moving, and a line slanted to the left indicates one moving to the left. You may have come across these (usually with time horizontally) as "displacement-time graphs" in high school physics. We take them a little more seriously in relativity, since spacetime is a thing - these are maps of spacetime, and the lines are the 4d objects inhabiting it. You see one 3d slice at a time.
So here's your scenario, with my extra "D" observer. A and B are marked in red and are stationary, C and D are marked in blue and moving to the right.
Note that, in this frame, C and D are closer together than A and B - the horizontal distance between the lines ("the space between them") is shorter.
We could mark on the diagram the start and end of the experiment - when C passes A and then B. Let's do that with fine red lines:
[snip]
Thanks.curiousburke said:robphy, you're stuff is next level. One careful read, and I understand maybe 50%. Just another infinity-1 reads and I'll fully get it :)
Seeing you add features to this spacetime diagram gave me an idea. Just to make things more complicated, what about adding a 3rd dimension to represent the perspective? Basically, spacetime diagrams are slices through a block of any possible rotation.
I thought the same thing, so left it ambiguous figuring you would know :)robphy said:It's not clear what to "add" in a third dimension. There may be something... but I'm not sure.
One should take care to find representations that faithfully represent the physics.
Here's the original diagram, followed by its boosted version.curiousburke said:I thought the same thing, so left it ambiguous figuring you would know :)
I'm thinking two different things, one is the velocity of a third frame from which the other two are measured, so 3d could smoothly transition from one frames perspective to the other.
Second, I'm still trying to conceptualize what it means, but hand wavey, it's the choice of x=0 relative to the observers.
Here's my clock-effect/twin-paradox spacetime diagram using the rotated graph paper.curiousburke said:I still think he has the best explanations of the twin paradox on youtube.
Sorry, you mean draw another slanted red fine line that intersects the point (event) where the B red thin line meets the C blue thin line. Then evaluate the spacetime distance between the first red fine line through A/C (i.e. A meets C) and the last red fine line and compare with the vertical distance between those 2 events along the vertical C blue thin line.Ibix said:View attachment 341329
If you ignore D for a moment, the only thing you can measure is the time between A and B reaching C - and here you can see that the time between those events as measured by C is shorter than the time measured by A and B, by comparing the vertical distance between the crossings.
No, I just mean measure C's proper time between meeting A and B, which corresponds to coordinate time in this frame.cianfa72 said:Sorry, you mean draw another slanted red fine line that intersects the point (event) where the B red thin line meets the C blue thin line. Then evaluate the spacetime distance between the first red fine line through A/C (i.e. A meets C) and the last red fine line and compare with the vertical distance between those 2 events along the vertical C blue thin line.
Yes, from the point of view of C along its worldline. But what about the difference of time between those two events (A meets C and B meets C) from the point of view of observers A and B (that share the same slanted red fine lines simultaneity convention) ?Ibix said:No, I just mean measure C's proper time between meeting A and B, which corresponds to coordinate time in this frame.
You could add a red line of simultaneity through B reaching C if you want, but you can't read red times off that graph without a calculation or robphy's clock diamonds.cianfa72 said:Yes, from the point of view of C along its worldline. But what about the difference of time between those two events (A meets C and B meets C) from the point of view of observers A and B (that share the same slanted red fine lines simultaneity convention) ?
No, it's fine. Nobody learns instantly and, as various other posters in this thread will know, I've needed things repeated a few times myself.curiousburke said:FWIW, Ibix, it's probably very frustrating working with people like me, sorry.
Yes, that was my point: in that diagram we add the aforementioned slanted red fine line through the event (B meets C) and calculate the spacetime distance between this and the other slanted red fine line through event (A meets C) along a straight line Minkowski-orthogonal to them.Ibix said:but you can't read red times off that graph without a calculation or robphy's clock diamonds.
