How Do You Solve This Complex Integration Problem?
  • Thread starter Thread starter Shannabel
    Exam Integration
22 replies · 3K views
Shannabel
find the integral from 0 to 3 of (5x^2+30)/(x^4+13x^2+36)
I thought it may be an integration by parts question, so I tried that first, but the book says that I should be using substitution.
So I tried using u=x^2:
du=2xdx
x=u^(1/2)
(5u+30)du/(u^2+13u+36)(2u^(1/2))
so now I have
(5u+30)du/(2u^(5/2)+26u^(3/2)+72u^(1/2))
but i have no better idea how to integrate that than i did the original equation. any ideas?
This problem would probably be best done by partial fraction decomposition first, then substitutions.
do you mean using something like
(Ax+B)/(x^2+4)+(Cx+D)/(x^2+9)=5x^2+30?
Not quite.
It would be
(Ax+B)/(x^2+4) + (Cx+D)/(x^2+9) = (5x^2+30)/[(x^2+4)(x^2+9)]
The goal is to solve for A, B, C, and D so that this equation is identically true.
Mark44 said:
Not quite.
It would be
okay, so i solved and got
A=0
B=3
C=0
D=2
so then i had
3/(x^2+4)+2/(x^2+9)
which i could integrate to get
3ln(x^2+4)+2ln(x^2+9)
and i could continue, but my possible answers all involve arctan so i think I'm on the wrong track here...?
A=0
B=3
C=0
D=2
so then i had
3/(x^2+4)+2/(x^2+9)
I didn't check your values for A, B, etc.
Your integrals are incorrect. You should not be getting log expressions, but you should be getting arctan expressions.
Also, check your work for the constants.
3/(x^2 + 4) + 2/(x^2 + 9) = (5x^2 + 35)/[(x^2 + 4)(x^2 + 9)] [itex]\neq[/itex] (5x^2 + 30)/[(x^2 + 4)(x^2 + 9)]
how do i get arctan expressions? because the derivative of tan is 1/(a^2+x^2), and i have 2 and 3 rather than 1 as my numerators?
sorry..
3/(x^2+9)+2/(x^2+4) ,right?
No, d/dx(tan(x)) = sec2(x).
d/dx(tan-1(x)) = 1/(x2 + 1) - that must be what you're thinking about.
Also, d/dx(tan-1(x/a)) = (1/a)/((x/a)2 + 1)
This implies that ∫(1/a)/((x/a)2 + 1) dx = tan-1(x/a) + C
i'm confused...
If d/dx (x2) = 2x, then ∫2x dx = x2 + C by integrating both sides. Mark just did the same thing with tan-1(x/a) where a is a constant.
okay i think that makes sense... but how can i use that to solve the problem?
That'll come in later; first check over your work for the constants in the numerators of the partial fractions. The numbers are almost correct.
i had
(ax+b)(x^2+4)+(cx+d)(x^2+9)=(5x^2+30)
ax^3+bx^2+4Ax+4B+Cx^3+9Cx+Dx^2+9D=5X62+30
A+C=0 and 4A+9C=0 therefore A and C both equal 0
B+D=5 and 4B+9D=30, so 5D=10 and D=2 so B=3
and i have
3/(x^2+9)+2(x^2+4)
:( can't figure out what's wrong!
Shannabel said:
i had
and i have
3/(x^2+9)+2(x^2+4)
This is correct. You can easily check by verifying that 3/(x^2+9)+2/(x^2+4) = (5x^2 + 30)/[(x^2+9)(x^2+4)]
Mark44 said:
This is correct. You can easily check by verifying that 3/(x^2+9)+2(x^2+4) = (5x^2 + 30)/[(x^2+9)(x^2+4)]
okay, so from here i should integrate and end up with arctan functions... how do i do this?
[tex]\int \frac{a~dx}{x^2 + a^2} = tan^{-1}(x/a) + C[/tex]
This formula is essentially the same as the one I gave in an earlier post.
A mistake you made earlier was thinking that the following was true:
[tex]\int \frac{dx}{x^2 + a^2} = ln(x^2 + a^2) + C[/tex]
More generally, this also is not true:
[tex]\int \frac{dx}{f(x)} = ln(f(x)) + C[/tex]
This should be: 3/(x^2+9)+2/(x^2+4).
To integrate the first term:
[tex]\int\frac{3\,dx}{x^2+9}=\int\frac{3\,dx}{9((x/3)^2+1)}[/tex]
[itex]\displaystyle =\int\frac{dx}{3((x/3)^2+1)}[/itex]​
Let u=x/3 → du=(1/3)dx
The integral becomes: [itex]\displaystyle \int\frac{du}{u^2+1}=\tan^{-1}(u) + C[/itex]
A=0
B=3
C=0
D=2
so then i had
3/(x^2+4)+2/(x^2+9)
Good eye - I missed that.
