How Do You Solve This Newton's Third Law Problem Involving Friction and Tension?
The discussion revolves around a Newton's Third Law problem involving two blocks, one of which is tied to a wall. The scenario includes forces such as tension and friction acting on the blocks, with a specific focus on calculating the acceleration of the lower block when a tension force is applied.
  • Participants discuss the application of Newton's laws and the summation of forces acting on the blocks. Questions arise regarding the calculation of frictional forces and the correct interpretation of the system's mass. There is also a focus on the forces acting on each block and how they contribute to the overall acceleration.
Participants are actively engaging with each other's reasoning, questioning assumptions about the forces involved, and attempting to clarify the setup of the problem. Some have provided calculations, while others express confusion about the correct approach and the implications of the blocks being tied or free to move.
There is a noted lack of clarity regarding the static coefficient of friction and the implications of one block being tied to the wall. Participants are also grappling with the correct interpretation of the forces acting on both blocks in the system.
irNewton
Newton Third Law problem. Help pleaseee!
The 1.0 kg block is tied to the wall with a rope. It sits on top of the 2.0 kg block. The lower block is pulled to the right with a tension force of 20 N. The coefficient of kinetic friction at both the lower and upper surfaces of the 2.0 kg block is uk = 0.370.
What is the acceleration of the 2.0 kg block?
Manipulations of F=ma.
I have given this two tries.
First try,
Fx=Fa2-Fk2-Ft+Fk1=ma
20N-(0.370)(3.0kg)(9.81m/s^2)-3.63N+(0.370)(1.0kg)(9.81)=3a
and I get it wrong..
How did you get 3.63N? Why did you add Fk1? I believe the summation of forces is 2a
Hmm but isn't the force being applied to the whole system which is 3kg?
anddd, Fk1 is the kinetic friction acting between block 1 and block 2 and 3.63 is the tension in the rope for block 1.
I was guessing all of the forces on block 1 and 2 should be taking into account...
I guess not?
Ops i misread the question didn't notice the 1kg mass is tied to the wall no wonder i don't understand why static coefficient is not given. If we say the force applied is F, is this force F in your free body diagram for the smaller mass? Maybe you can try looking at just the 2kg mass and draw the free body diagram and resolve the forces. Does it give you the correct answer?
I already tried adding up the sum of all the forces only on block 2 and got a wrong answer :(
Mind writing out how you do it?
20N-0.37*2*9.8=2a
6.4 m/s = a
this is wrong :(
0.37*2*9.8 is the frictional force between the smaller mass and the bigger one how about the friction between the bigger mass and the floor?
  • · Replies 21 ·
11K
11K
