How does a bended circular waveguide transform TE and TM modes?
  • Thread starter Thread starter Ricvil
    Mode
A bended circular waveguide can transform TE01 modes into TM11 modes, as demonstrated by mode coupling theory. The discussion raises questions about the reversibility of this transformation, suggesting that the same waveguide could convert TM modes back to TE modes due to temporal reverse symmetry. Additionally, it explores the concept of parity/mirror symmetry, proposing that cutting the converter and closing one end could allow for the reflection of TM modes when TE modes are injected. The HE11 mode is clarified as a result of the conversion process from TM11, highlighting the complexity of mode transitions. Overall, the conversation emphasizes the intricacies of mode conversion and the challenges in distinguishing between modes in reflection-type converters.
Ricvil
http://ir.hfcas.ac.cn/bitstream/334002/12022/1/Mode%20converters%20for%20generating%20the%20HE%2011%20%28gaussian%20like%29%20mode%20from%20TE%2001%20in%20a%20circular%20waveguide.pdf
In the above article, the mode coupling theory shows how a bended circular waveguide transforms a TE01 mode into a TM11 mode.
Of course, always will be spurious modes in the process.
My questions are about :
1- By temporal reverse symmetry , the same bended pipe can transform both TE into TM and TM into TE modes?
2-By Parity/mirror symmetry, if one cuts the same converter at it's half length and close one of the ends with the same metal of the waveguide, then if one inject a TE mode at the other open end, one gets a TM reflected mode?
HE11 is not the same as TM11. However, I am sure the mode transition must operate in both directions by reciprocity considerations, and also in the reflection method you describe.
Thank you for the answer.
About the HE11 in the article, it is obtained from TM11 resulting from the first stage of conversion, TE01-TM11-HE11.
Thanks for the clarification.
In the case of the reflection-type mode converter. I cannot see how you can easily separate the two modes present at the port.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
