How Does an Air Bag Utilize Physics to Save Lives?
  • Thread starter Thread starter daisy_polly
    Air Work
An airbag consists of three main components: the nylon bag, a collision sensor, and an inflation system that uses a chemical reaction to produce nitrogen gas for rapid inflation. The sensor activates the airbag upon detecting a collision force equivalent to hitting a brick wall at 10 to 15 mph. The inflation system operates similarly to a solid rocket booster, allowing the bag to deploy quickly and then deflate through designed holes. Understanding the physics behind airbags involves applying Newton's laws, particularly how they reduce acceleration and force during a crash, thereby enhancing safety. This explanation effectively combines technical details with fundamental physics concepts.
daisy_polly
Hi,
How does an air bag work?
I know a lot about how an air bag work as I am a physics grade11 student but I am confused how to really answer the question.Should I answer it techanically or use Newtons law to answer it.
Thanks in advance.
An early reply is appreciated.
Daisy.
airbag
There are three parts to an air bag. First, there is the bag itself, which is made of thin, nylon fabric and folded into the steering wheel or the dash board. Then there is the sensor that tells the bag to inflate. It detects a collision force equal to running into a brick wall at 10 to 15 miles per hour (16 to 24 kph).
Finally, there is the inflation system. Air bags are actually inflated by the equivalent of a solid rocket booster. Sodium azide (NaN3) and potassium nitrate (KNO3) react very quickly to produce a large pulse of hot nitrogen gas. This gas inflates the bag, which literally bursts out of the steering wheel or dashboard as it expands. About a second later, the bag is already deflating (it has holes in it) in order to get out of your way.
© 1998 - 2004 HowStuffWorks, Inc.
u can find more at http://www.howstuffworks.com/question130.htm
thanks
Thanks!:smile:
how should I answer the question as my teacher is not actually teaching us all that about the air bag but gave us this question.
We are learning about Newtons laws.
Try this line of reasoning: When you crash, your speed is changing from X miles per hour to zero. Thus you are being accelerated, which means a force is being applied to you. Without the airbag, you smack into the dashboard which brings you to a stop rather quickly---high acceleration, high force: not good! The airbag slows your acceleration---lower acceleration, lower force: good!
Make some sense?
Thanks so much for your help.
Same impulse; different maximum force.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
