rcgldr
Homework Helper
- 8,948
- 687
There are several reasons for helicopter rotor inefficiencies. One issue is that the relative speed at the inner part of the rotor is much less than the outer speed. Another issue is that a cambered airfoil produces a downwards pitching torque that would put too much stress on a rotor blade and it's support, so a helicopter rotor uses a nearly symmetrical airfoil. Similar to a propeller, there is washout, and the washout near the outer tips is set to reduce lift and the associated vortices that would otherwise be generated.sophiecentaur said:Is there some transition between the way a helicopter wing and a fixed wing works, then? The difference in efficiency is just a difference in detail - it doesn't have to he 'in principle'. In fact, how can it be? The only difference is surely that the helicopter blade effect is hundreds of times more on the same local region of air around it.
A hovering helicopter has to deal with it's own induced wash, and for some helicopters, it's unsafe to vertically descend into the downwash because there's not enough power to stop the descent. For a helicopter in forward flight there's much less induced wash, and forward flight takes less power than hovering.
The core principle is the same, lift is the result of accelerating air downwards, via diversion of the flow relative to a rotor blade, propeller blade, or a wing.
but not the impulse. The impulse may get spread out over a large area, but the magnitude of the impulse does not diminish over time or distance until some other force or impulse opposes it. As pointed out in several posts, the average force that the atmosphere applies to the surface of the Earth is the sum of the weight of the atmosphere and the weight of any aircraft (or hovering balloons) that the atmosphere is supporting, it's a closed system.sophiecentaur said:energy gradually dissipates.
Wind tunnels that are too "short" prevent vertical air flow, and essentially model a wing in a combination of ground effect and "ceiling" effect (air prevented from flowing downwards from above).sophiecentaur said:behaviour in a wind tunnel though.
