How does carbon monoxide cause soda cans to explode?
  • Context: Undergrad
  • Thread starter Thread starter DBBPhysics
    Carbon Cause
43 replies · 10K views
DBBPhysics
I just read an article about the hazards of the keyless feature on new cars (https://www.nytimes.com/2018/05/13/...less-cars-and-their-carbon-monoxide-toll.html). Apparently, it can be easy to not know a car is still running in the garage even though one might think that the car must be not running because the key fob is on the person after going into the house. Therefore, there have been deaths due to carbon monoxide poisoning. One thing noted in that article was that soda cans can explode in the presence of carbon monoxide. I don't understand what physics are at hand that would cause that to occur. For the cans to explode, the pressure inside must be larger than the pressure outside the cans. If the pressure outside the cans is lower than normal, would not the garage implode before the cans explode or at least cause air to infiltrate the garage instead of imploding? Can anyone explain it to me?
Thanks
Hmmm. I've never heard of this before, and a quick google search turned up nothing. I'd remain skeptical for now.
I would think it was the heat, not the carbon monoxide. Having a car idling in your garage is the equivalent of about 10 electric space heaters.
I thought that the emission control would turn the engine off before there was more than a safe level in the garage. Was it just an urban legend that it is now difficult to kill yourself with a tube from the exhaust pipe? Perhaps I am just gullible.
Air would infiltrate, enough to prevent an implosion.
Look at the photograph of the exploded cans of Pepsi. They all failed at the seam around the lid. Moreover, the Pepsi cans are staked atop other cans that appear to be identical except they contain some other kind of beverage. I can't tell from the little bit of can that shows in the photo, but they appear to cans of soda also. Perhaps Mountain Dew? Can anyone tell?
I believe Mountain Dew and Pepsi are made by the same company.
My first guess is that there's a seal around the lid of the Pepsi cans that fails in the presence of carbon monoxide.
Anyway, everyone should have a CO detector in their home. I have two, one is a dedicated CO detector and the other is part of a smoke detector. I am now seriously thinking about putting one in my garage, too.
CWatters said:
I note that was attributed to a victims son.
Yes, maybe that is the answer: the son made the comment that the cans exploded because of the carbon monoxide rather than an expert making that claim and the writer for the NYT did not check it out his statement (I'm shocked!...).
Must be an urban legend. I can't imagine why - or even how - a car would be programmed to do that.
[edit]
I'm wondering though if it is a myth that it is CO that kills you in the common suicide scenario. CO2 seems more likely to me.
Mister T said:
Look at the photograph of the exploded cans of Pepsi. They all failed at the seam around the lid...
Well:
1. Google tells me CO is not corrosive at low concentrations and atmospheric pressure.
2. As far as I know, the seal is mechanical: it is crimped.
3. You can see the kids are bulged from being under excessive pressure.
Agreed.
There is a sealing compound added to the crimped seal to keep it airtight, but I can't imagine it would cause a can to explode if degraded.
I read the article, then came here because I googled that same question. I have a solution to the mystery of the exploded cans.
A father was living in the house. He was the one who was killed by the CO. The son inspected the house after the incident. He found the exploded soda cans.
My theory is that those cans had exploded before the CO incident. Perhaps the father had left them in a hot car and they exploded. He just took them and put them in the garage. Later (perhaps years later) the father was killed by CO. So there is no connection between the exploded pepsi cans and CO. Mystery solved.
Seems unnecessarily convoluted compared to my simpler explanation, to me.
I wouldn't call what I saw in that photo an explosion. If anything, it looks like a safety mechanism was activated to prevent an explosion.
Is what we see in that photo consistent with that explanation? Only the Pepsi cans failed, and all the Pepsi cans failed. And all at the same place, the seam around the lid.
Not a physicist, but it looks like the cans below Pepsi are YooHoo, not carbonated. In the NYT picture, there looks like Pepsi residue on the lids of the cans below- especially on the right (but not as much as one would expect) and little bits of spatter on the package of what looks like paper towels to the left, and plastic sheeting on the right. Heat would make sense, think of all of the heat energy in a gallon of gas, let alone however many were burned while the car was idling. Truly sad, however.
Am I missing a photo? I don't see a picture that includes soda cans anywhere in the article.
The Pepsi cans are higher up than the other cans, and stratification is pretty substantial in a situation like this. And there are other potential factors: they may not be identically constructed, the liquids may not be identical and the ones on the bottom may be sitting on something that could conduct heat away.
Also, if you look closely at the pictures you can see the tops themselves are bent outward, indicating they were substantially pressurized before the crimp let go.
...although the article appears to have been edited to remove the photo.
The article has been revised to remove the bits about the cans. See https://imgur.com/a/d9w7XWa
It appears to have been removed -- possibly they realized the error in the explanation. I'll see if I can find a copy in my cache or on my cell phone to upload.
To me, the key that says elevated internal pressure is the fact that all the tops that failed popped from concave to convex, indicating higher than normal internal pressure before the seal/crimp joint gave way...plus several cans that didn't open up still have their tops popped convex.
Unfortunately, I've experimented with this myself...
Perhaps it was the heat of the engine running in an enclosed garage that did it. But... if the cans opened from heat while in the location shown in the picture there should be quite a sticky mess.
There are actually two kinds of Pepsi in the picture. I am going to guess the guy wanted to do a taste test and impatiently put them in a freezer to chill. They blew up then he took them out. Later on he died.
In light of the fact that all references to the soda cans were deleted now in the article, I agree with this theory.
Copied the photo from the NYT article, I will post it.
Thank you! That picture was nowhere to be found when I looked at the article.
Perhaps the cans exploded because of the heat?
The problem with this theory is that it requires an entire back-story including several assumed actions that don't make sense. It's possible, but Occam and I prefer simpler explanations.
CWatters said:
Perhaps the cans froze over winter and ice pushed out the tops?
In Boca Raton? Not likely!
The culprit was undoubtedly heat. Check out a can of Coke left in a car in the hot sun:
http://www.philly.com/philly/news/y...nough_to_explode_a_Coke_can_inside_a_car.html
Look familar? The heat drives the CO2 out of solution, cramming the gas into the small dead space above the liquid. When the lid blows off, the gas escapes, and the liquid is left sitting there largely undisturbed.
(The drink in the yellow cans is Yoo-Hoo, which is not carbonated and is therefore immune to this problem.)
Possibly related to the heat from a running engine, in a closed garage, in Florida, but it has nothing to do with the carbon monoxide.
Likes   Reactions: Asymptotic, russ_watters, Herman Trivilino and 1 other person
Any cold liquid that contains water will adsorb carbon dioxide. Some people claim hot beer & Hot soda is bad because all the carbon dioxide is released at about 85 degrees. Carbon dioxide is still inside the un opened can but no longer adsorbed in the liquid, pressure will be higher in a hot car or in the hot sun. If you put un opened containers of hot beer & soda in the refrigerator for 1 week in cold temperature carbon dioxide is adsorbed back into the liquid. If you throw a cold soft drink into the air nothing much happens when it hits the ground. If you throw a hot soft drink into the air when it hits the ground it explodes. That is the physics of carbon dioxide not sure how that applies to carbon monoxide unless HOT car engine exhaust causes soft drinks to explode.
At the bottom of the article:
"Correction: May 14, 2018
An earlier version of this article included a quotation from a family member of a carbon-monoxide poisoning victim that referred incorrectly to the cause of an explosion of Pepsi cans in the victim’s garage at the time of the fatal episode. (The error was repeated in a caption.) The explosion of the soda cans was most likely caused by heat; a carbon-monoxide buildup would not cause such an explosion."
