Understanding Electrolysis: How Do Ions and Current Flow?
  • Thread starter Thread starter Deep_Thinker97
    Electrolysis Work
Electrolysis involves a cell connected to two electrodes, one positive and one negative, placed in an ionic solution. When a battery is connected, it creates an electric field that causes positive ions to move towards the negative electrode (cathode) and negative ions towards the positive electrode (anode). The current is defined by the movement of both positive and negative charges, with their contributions adding constructively to the total current. The positive electrode becomes positively charged as electrons flow from the anode to the battery's positive terminal, while the cathode gains electrons from the battery's negative terminal. This understanding clarifies how current flows and how ions interact during the electrolysis process.
Deep_Thinker97
Right, I've started physics a level and electrolysis has always confused me since gcse, so please be very detailed!
This is what I know, (or assume) so far: there is a cell; that cell is connected to two electrodes; one is positive, the other is negative. The electrodes are placed in an ionic solution, where positive ions move to the negative electrode and negative ions move to the positive electrode.
I don't understand how current moves throughout the process. How do the electrodes get their charges in the first place? And overall, what direction does the current flow if the ions in the solution move in both directions!
Please help me!
You attach the electrodes to a battery which makes one negative and one positive. An electric field will be produced between the two electrodes, and charges in an electric field experience an electric force. The positive and negative ions experience forces in the opposite direction.
The current takes the sign of the charge as well as its direction into account. A positive charge moving right to left gives the same current as a negative charge moving left to right. When the positive and negative ions move in opposite directions, they both add constructively to the total current.
1 amp of negative charge moving one direction + 1 amp of positive charge going the opposite direction = 2 amps total.
Whichever way you define this total current is a matter of convention, and I've forgotten which way humans conventionally decided on.
A battery is connected to two electrodes put into a solution.The positive electrode is in the side of positive terminal of battery and vise versa.(Because the electrons in the Anode(Positive electrode) moves towards the positive terminal of battery making the electrode positively charges and vise versa).The cations move toward the cathode(negative electrode) and gets discharged,so,gaining electrons.The Anions(negative ions)moves toward the anode(positive electrode)giving electrons to the positive electrode which travels to the positive terminal,thus electrons flow through the circuit.
Thank you, i understand the process more now
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
