How Does Energy Transfer in a Triangular Wave Pulse?
  • Thread starter Thread starter applestrudle
    Energy Pulse Wave
3 replies · 5K views
applestrudle
one end of a fixed string is moved transversly at a constant speed u for a time τ and is moved back to it's starting point with velocity -u during the next time interval. as a result a triangular pulse is set up and moves along the string with speed v. Calculate the kinetic and potential energies associated with the pulse, and show that their sum is equal to the work done by the transverse force that has to be applied at the end of the string.
Work = F x displacement
Power = Work x time
PE density = T/2 (dy/dx)^2
KE density = μ/2 (dy/dt)^2
v = (T/μ)^0.5 (T = tension)
the triangle pulse:
y = A f(x-vt)
KE density = μ/2 A^2[-vAf'(x-vt)]^2
PE density = t/2 A^2 [f'(x-vt)]^2
using v = (T/mu)^0.5 you get that PE = KE therefore
total energy density = μ A^2 v^2 [f'(x-vg)]^2
work = power x time
W = T x u x 2τ
-TvA[f'(x-vt)] x 2τ
I can't seem to rearrange them to get them the same. I tried using v = λ/(2τ)
thank you
I guess "g" is a typo and you mean t?
If you replace v^2 by T/μ there, the equations get more similar.
W = T x u x 2τ
I don't understand where this comes from. The force required to move the line is not T.
Isn't the force your putting on the end of the string the tension T?
