How does light illuminate objects? (help me in a debate)
  • Thread starter Thread starter General_Sax
    Light
This discussion centers on the nature of light and its role in illuminating objects, particularly in the context of a debate about physical and non-physical entities. Participants assert that light interacts with physical objects through reflection and refraction, allowing visibility. They clarify that non-physical entities cannot be visible since visibility requires interaction with light, which necessitates physical matter. The conversation also touches on optical phenomena such as holography and mirages, emphasizing that these effects are rooted in physical principles.
  • Understanding of light behavior, including reflection and refraction
  • Familiarity with optical phenomena such as holography and mirages
  • Basic knowledge of physics concepts related to matter and energy
  • Awareness of the limitations of visibility in relation to physical entities
  • Research the principles of light reflection and refraction in physics
  • Explore the science behind holography and its applications
  • Investigate the optical effects of mirages and their physical explanations
  • Study the relationship between visibility and physical matter in scientific contexts
Students of physics, optical engineers, and anyone interested in the scientific principles behind light and visibility, as well as those engaged in philosophical debates about physical versus non-physical entities.
General_Sax
How does light "illuminate" objects? (help me in a debate)
Hello,
I'm curious as to how light illuminates an object. To be more specific how does light allow give an outline to a body?
Can an seemingly physical object be visible to the naked eye and at the same time be non-physical? I know this seems like a nonsensical question, but I'm having a debate with a person and need 'backup' so to speak. I'm trying to make the claim that if a non-physical entity is visible, then the object can not be non-physical, because the wavelength of the light would not be interrupted.
If anyone can provide a link or source I would appreciate it greatly.
I know that the wavelength of the light an object is viewed under is somehow a limiting factor in resolution. However, I'm not sure if this relates to my question or not.
P.S. I may have made spelling mistakes, but I'm in a rush, so please forgive me.
Science news on Phys.org
A "seemingly physical object" such as a... ?
A "non-physical entity" such as a... ?
Light bounces off of objects that are not transparent/translucent and your eye receives the light and process it to form a visual image.
It is possible to have an "invisible" object that is 100% real, but that would involve a variety of tricks and optical effects.
Also, I'm not sure what you mean by a non-physical entity? Non physical to me implies that it has no substance, it isn't made up of matter or energy, as both are physical to me. In the context of physics and science, there isn't anything that can exist and be non-physical.
Now if you want to talk about ghosts or something, that is not in the realm of science and no one can give you an answer for.
It's a long story...
Thanks Drakkith.
Light can be generated directly or reflected off of material objects with varying wavelength absorption and reflection. Lightning or sparks, for example are visible but not because light is reflecting off matter. Likewise, a flame (I believe) is visible because the radiation emitted by the combustion is refracting around the air as it rises turbulently, so that is in one sense physical in that the air is physical, but it's not like the light of the flame is generated by the air itself. Actually, I might be wrong and it is the combustion of flammable gasses themselves as they rise that create the visible flame. Maybe someone else can clear this up.
What about a rainbow, though? Rainbows are caused by an array of water-droplets acting as prisms. So, although there are physical water droplets involved, the bands of color visible are not the droplets themselves, b/c from another angle they would not appear.
I think he means like a holographic projection.
such things are impossible, i believe
Certainly impossible with only one projector.
How would it be possible, even with a million projectors, if you were, say, in a vacuum?
Holography, mirages, and other optical tricks are all caused by physical phenomena. Now, I'm assuming a "Non-Physical Entity" is something like a ghost?
It should be possible to do some elementary shapes with a well-chosen gas, and a few intersecting, well-shaped beams (at least a cube!).
Anyway, here's something nice:
http://www.optigone.com/3D_hologram.htm
http://www.tradeshowhologram.com/video.html
Well you would need a well-chosen gas.. in that case, you could cram, say, 20 projectors into one encasing and walla - hologram
11K
14K
