How Does Lorentz's Equation Transform into Cauchy's Law?
8 replies · 3K views
DannyJ108
New user has been reminded to show their work on schoolwork questions
Prove that when frequency is small, the Lorentz model for a refractive index in dielectrics becomes Cauchy's empirical law
##n^2(\omega) = 1 + \frac {\omega^2_p} {\omega^2_0 - \omega^2}##
##n(\lambda)=A+\frac B {\lambda^2}##
Hello fellow physicists,
I need to prove that when ##\omega << \omega_0##, Lorentz equation for refractive indexes:
turns into Cauchy's empirical law:
I also need to express A and B as a function of the Lorentz model parameters: ##\omega_0## and ##\omega_p##, where:
##\omega_0##: resonant frequency
##\omega_p##: plasma frequency
Any idea on how I could approach and do this?
Thank you in advance!
Do you know how to approximate ##\large \frac 1 {1-x}## when ##x \ll 1##?
Yes, I do, but I don't know how I would get that expression with the equation I have. If ##\omega << \omega_0## , the equation would result in:
##n^2(\omega) = 1 + \frac {\omega^2_p} {\omega^2_0}##
Whoa. :wideeyed: That's going too far.
If ##\omega \ll \omega_0##, how does ##\frac {\omega^2} {\omega_0^2}## compare to 1?
If you let ##x = \frac {\omega^2} {\omega_0^2}##, can you rearrange the denominator in ##n^2(\omega)## to get a factor of ##1-x##?
DannyJ108 said:
Homework Statement:: Prove that when frequency is small, the Lorentz model for a refractive index in dielectrics becomes Cauchy's empirical law
Relevant Equations:: ##n^2(\omega) = 1 + \frac {\omega^2_p} {\omega^2_0 - \omega^2}##
@DannyJ108 -- You are required to show more work at PF. Please use the hints provided by @TSny to motivate you to post your best efforts on this problem. Thank you.
I have rearranged the equation to get:
##n^2(\omega)=1+\frac {\frac {\omega_p^2} {\omega_0^2}} {1-\frac {\omega^2} {\omega_0^2}}##
Since ##\omega << \omega_0##, ##\frac {\omega^2} {\omega_0^2}## will be smaller than 1, so I can expand that fraction as a Taylor series to get:
##n(\lambda)=\sqrt{1+\frac {\omega_p^2} {\omega_0^2} + \frac {\omega_p^2} {\omega_0^4}4\pi^2 c^2 \frac {1} {\lambda^2}} (eq.1)##
Where I have used: ##\omega=\frac {2\pi c} \lambda##
However, in Cauchy's law, ##n## is not squared:
So I don't know how I could group the terms in ##eq. 1## to establish the ##A## and ##B## coefficients, I do however get the ##\lambda^2## in the denominator, so that's a good thing.
How could I proceed from here?
How would you approximate ##\sqrt{a + b}## assuming ##b \ll a##?
But I'm not approximating ##\sqrt{a + b}## I'm approximating:
##\sqrt{1 + a + b}##
Let ##a' = 1+a##. Then you have ##\sqrt{a' + b}##.
