- 6,040
- 3,162
It might be of interest at this point to look more closely at the EMF that gets generated when a loop containing ## N ## coils is introduced. We could just use Faraday's law with the flux being ## N ## times as much, but I did notice there is a way to explain this using the ## E_{induced} ##. See https://www.feynmanlectures.caltech.edu/II_22.html
This one is subject to some interpretation, but right after equation (22.3) Feynman says there can be no electric fields inside an ideal conductor. I interpret that as saying there arises an ## E_{s} ## in the conductor, where ## E_s=-E_{induced} ##. This ## E_s ## will integrate along the path inside of the coil to give it the factor of ## N ## times the EMF of a single loop. In addition, external to the ## N ## loops, it must also give this same result, since ## \nabla \times E_s =0 ##. This (the electrostatic component) is what I believe we measure with a voltmeter when we measure the EMF from the coil. See also post 27 above and the thread that is linked. In private discussions (PM) with others, I don't have complete agreement on this, but perhaps you @alan123hk might concur. The connections of the leads to the voltmeter can be close enough together that we clearly aren't measuring the ##E_{induced} ##, but the integral ## \int E_s \, dl ## between two points must be path independent, and thereby gives the same result that it does going through the voltmeter and voltmeter leads, as it does through the coil, resulting in a very reliable voltage measurement.
Then there is also the case of a single loop that is open, the subject of the Walter Lewin paradox, where it matters which side of the localized changing magnetic field the voltmeter is placed, but that is a separate problem, and it has already been discussed in detail. For that case, the voltmeter is also seeing ## E_{induced} ##, and how much (integral of) ## E_{induced} ## that is observed (depends on location of the meter) makes a difference in the measurement.
For ## N ## in the above, the location of the meter could make it ## N \pm 1 ##, etc., which usually doesn't have a significant effect in the voltage reading, provided ## N ## is fairly large.
See also https://www.physicsforums.com/threa...-voltage-across-inductor.880100/#post-5529838 post 22.
