How Does Mass Affect EMF in a Rotating Loop with Constant Angular Velocity?
6 replies · 3K views
eoghan
Hi! I have a problem with this exercise:
A squared loop of length L and mass M can rotate around one of its vertices and it's on a vertical plane. In the region below the suspension point there is a uniform magnetic field B perpendicular to the plane of the loop.
If the loop rotates at a constant angular velocity w, find the electromagnetically induced EMF.
Here's a picture:
http://www.allfreeportal.com/imghost/thumbs/756421Untitled1.png
[tex]\phi(B)=\frac{L^2B}{2}tan(\omega t)[/tex]
[tex]EMF=-\dot{\phi}(B)[/tex]
Now the question: why does the text tell me the mass of the loop?:confused:
Has it something to do with the fact that the angular velocity is constant?
I don't think M is necessary. If there is a second part to the question, it may be relevant there.
However, you should take a second look at your expression for φ.
Based on the units you are using, φ is the magnetic flux.
[tex]\phi = \int B dA[/tex]
For a uniform field and an area A inside that field,
[tex]\phi = B \int dA = B A_{inside\hspace B}[/tex]
According to your φ, it goes to infinity every half period, which would imply that either L or B goes to infinity, which is not the case.
To find φ properly, it is necessary to express the area of the loop that is in the magnetic field as a function of angle, and hence a function of time. As the loop is a square, the expression may be a little complicated.
Next, Farady's Law of Induction tells us:
[tex]EMF = -\frac{d \phi}{d t} \neq -\phi[/tex]
Note that when the entire loop is completely above or below the suspension point (a whole π radians of its motion per cycle), φ is constant, and hence EMF = 0.
Yes, there is a second part: calculate the energy dissipated in one oscillation by the induced current.
I can only imagine energy being dissipated if the loop has a finite resistance.
I hope the question gives more information on what the loop is made of.
Once you have found the EMF as a function of time, you will be able to find power, and hence, by integration over one cycle, the energy dissipated.
