How Does Membrane Thickness Affect the Electric Field in a Nerve Cell?
The discussion revolves around the effect of membrane thickness on the electric field in a nerve cell, modeled as a parallel plate capacitor. The original poster presents a problem involving the calculation of the electric field based on given parameters, including surface charge density and membrane thickness.
  • The original poster attempts to apply the formula for electric field in a parallel plate capacitor and questions how membrane thickness influences the electric field. Some participants suggest that thickness may not matter, while others express uncertainty about its relevance.
Participants are exploring different interpretations of how membrane thickness affects the electric field. Some guidance has been provided, but there is no explicit consensus on the role of thickness in the context of the problem.
There is a focus on understanding the relationship between electric field and membrane thickness, with participants questioning assumptions about the parallel plate capacitor model and its implications for the problem at hand.
la3
The cell membrane in a nerve cell has a thickness of 0.12 micrometers.
(a) Approximating the cell membrane as a parallel plate capacitor with a surface charge density of 5.9 x 10^(-6) C/m2, find the electric field within the membrane.
(b) If the thickness of the membrane were doubled, would your answer to (a) increase, decrease, or stay the same. Explain.
Can anyone help me get started on this? I think one of the formulas to use would be something like:
E = sigma / permittivity of free space
where E= electric field, sigma= charge density, and permittivity of free space= 8.85 x 10^-12
I am unsure how the membrane thickness comes into play.
Sounds like you're on the right track. It's up to you to determine if membrane thickness affects the field within. :wink:
I cannot see how membrane thickness matters since it would only affect A (area), but A cancels from both sides of the equation.
However, since it is included in both parts (a) and (b) I feel that thickness probably matters...
If you mean plate area, then thickness--the distance between the plates--has nothing to do with it.
They want to know if you know what matters and what doesn't.
Well I am going to have to say that membrane thickness does not matter since the electric field is constant within a parallel plate capacitor since both plates run exactly parallel to each other.
The voltage (perpendicular to the electric field lines) will change as you move from one plate to another (ie. as equipotential lines), but the electric field remains constant.
So, for (a):
E = (5.9 x 10^(-6) C/m2) / (8.85 x 10^(-12) C2/Nm2)
E = 6.7 x 10^5 N/C
And for (b):
The answer to (a) would stay the same for above reasons.
How does this sound?
Perfecto! :approve:
Haha... great! Thanks for your help!
I had a hard time visualizing the problem on my own.
  • · Replies 30 ·
  • · Replies 20 ·
