How does output voltage of an electric guitar work?
  • Level: High School
  • Thread starter Thread starter Xenon02
165 replies · 16K views
Xenon02
Hello !
I've got a problem understanding the pickup ? or the sound ? I don't know I got very confused. I wanted to learn how to make guitar effects although I don't know much about music but I wanted to make. On this website : https://sound-au.com/articles/guitar-voltage.htm Here the Peak voltages of E1 is 100mV and E2 is 300mV, the thing is when there is a chord, I guess it is a E1 and E2 played at the same time so E1 + E2 is 300mV it is the same as single E2 which is also 300mV. That doesn't make any sense to me ... So single string makes E1 sound, and another single string makes E2 sound but playing both strings E1 and E2 makes the same sound as E2 ??????
Second thing is my experimentation. I know about interference and phase shift of the signals. But interference means that the sinewaves must add up to each other right ? Here are the images and the link : https://www.geogebra.org/graphing/merap3ws, so the orange function is the sum of 3 sinewaves (f(x),g(x),h(x)). So f(x) is let's say E1, g(x) is E2 and h(x) is E3 so we have 3 strings (guitar has 6 strings the classic one).
We play all 3 string at the same time so we have 3 sinewaves adding to each other sometimes the sum exceeds value "1" which here it is "3". How does the pickup makes these sound into voltages ? for peak sound "1" it is 0.7V or for peak sound of "3" it is 0.7V ? The maks that pickup can make is 1V but I said 0.7V because it is easier. How does it work ??? What if we have sound that has "20" as a value how does the pickup changes the sound sinewaves into voltage sinewaves ?
Hence I couldn't understand why the output of the guitar is maks 1Vpp or 1V I guess ?
I got so lost because these sums are exceeding this value of "1" and how the pickup "knows" what is the pick of the sound or when he uses maks voltage, when the sound peak is "300","3000" etc ? The sums of the sinus can be a lot.
PS. If it's possible to make is simple for goofball like me.
I think @pinball1970 is a guitar player, maybe he can help here.
  • Love
Yea would be helpfull because I just don't get it how the pickup works, because I have some interference knowladge and I shown the pictures of how the sinus can add up and have peak value like "3", "10", etc. but how the pick up works and "knows" what is the maks amplitude and changes it into maks amplitude in voltage instead of maks sound wave amplitude. If what I said makes any sense at all.
Here is a good article on how electric guitar pickups work: https://www.yamaha.com/en/musical_instrument_guide/electric_guitar/mechanism/mechanism002.html
Also, when you are adding multiple sine waves of different frequencies, it is usually the RMS values that you add, not the peak values. You would only add peak values if they were coherent sine waves of the same frequency and phase.
More background on mixing sounds of different phases and frequencies: https://nsinstruments.com/principles/linear.html
Drummer but I do hang around with those guys. I'll pass it on.
A simple explanation: The pickup is just a transducer. For a guitar, the pickup magnetizes the guitar strings and the motion of the strings then induces a voltage in the coil inside the pickup. This voltage is then passed through a circuit where it is ultimately amplified and sent to a speaker or some other device for playback and/or recording.
The pickup itself 'knows' nothing. It merely responds to the changing magnetic field produced by the vibrating strings. It does no adding of frequencies or anything else. The maximum amplitude is determined by the strength of the magnetic field of the strings and how quickly it is changing, which is proportional to the how fast the strings move. To be honest, the peak amplitude of the voltage signal is mostly irrelevant. As long as the signal is strong enough to be amplified effectively without undo noise then the peak amplitude doesn't matter. If it's a little too low then you just turn up the volume knob and vice versa.
Also note that there is no sound wave mentioned here. This is because the pickup does NOT detect sound waves in air. It directly detects the motion of the strings. You could, of course, use a microphone to detect sound waves in the air, such as what you would do to record someone playing an acoustic guitar without any pickups, but that's not how an electric guitar works.
pinball1970 said:
Drummer
arghh sorry, I do know that. I remember your posts about playing gigs and the ones about "original or cover"
They do not add up ? Is it not like interference ? Why ?
Sounds a bit weird because usually learning about amplitude of waves meeting at some point interfere with each other.
Same goes to RMS, why RMS ? The waves meet at some point and that point is being interfered so peaks or some part of that signal is being interfered. In the article I sent showed some signals and their RMS and peaks.
So how each note are distinguished ?
Can I add up individual 2 signal and will give me the same result as 2 signals played at the same time.
Let's say I play E1 and this is one signal, then I play E2 and this is second signal and at the end play E1 and E2 at the same time. Adding the results of individual E1 and E2 gives me the same signal of E1 and E2 played at the same time ?
Because if I want to amplify some sound like E1 I have to somehow exclude him from the sound signal that contains all the sounds/signals. Od does superposition work here ?
Aha so my thinking of the sound waves is pretty useless here, because if it was sound wave then the peaks of Sound are a bit questionable because they can exceed some value like I showed in geogebra. Or maybe that is also a bad thinking even for microphone because the signals should interfere like in my pictures resulting in high amplitude peaks !!!
But yea so if the pickup works a bit different and the amplitude is determined by the vibration but what about distinguishing the sounds ? Does the superposition work ? Or rather how pickup creates complex signal when many Strings wibrates. If superposition works then maybe pickups gives the final results only, but still consist of all sound and can be distinguished using superposition. Separate sounds equal to the sum of these sums.
Maybe I am right or not ;>
PS.
Isn't the vibration some sort of Sound wave ? It must be also a sinus so it shows the same problem maybe when it comes to adding sinuses up.
Or like why the sound from pick up that add up doesn't exceed the 0.7V maks when individuals can have 0.3V in my geogebra I've shown that adding 3 signals can exceed huge value let's say single sound from string makes 1V so 2 sound with different frequencies makes sound that there is a peak exceeding 1 V. Weird.
https://www.informit.com/articles/article.aspx?p=2355856&seqNum=5
Here I have found something interesting.
The author says that sound that add up using superposition and scales it to +1 and -1 so even if we have a sound that exceeds the value 1 after superposition it is scaled back to +1 and -1 as if adding more sound at the same time makes all individual sound smaller than originally.
Let's say I play E1 and the E2 they have amplitude of 0.3V but if I play E1 and E2 at the same time the final result is the same but E1 and E2 have smaller amplitude than the individual sounds.
Weird that adding sounds reduced their individual amplitude.
PS.
Although here the two so waves added exceeds value "1" and aren't scaled to +1 and -1. So I am lost here when it comes to exceeding some value of amplitude. Or how superposition works in pickups or how Vibration that is similar to the sine wave sound because it creates the sinus signal must add up but never exceeds value 1V weird
What I'm getting at is that the pickups simply turns the motion of the strings into a voltage signal. The string itself is what is moving. Distinguishing different frequencies takes place in your ear or when you pass the signal through the appropriate circuit.
Yes.
Ideally the pickups should only pick up the motion of one string each. But even a single string will not vibrate at a single frequency thanks to overtones, so you will never have a pure sine wave signal. And again, the pickup is not doing any frequency summing or anything else. It simply responds to the movement of the string with an output voltage. The physics of the string itself determines how it vibrates and gives it all of the different frequencies when plucked.
Edit: Apparently I was incorrect about each pickup only detecting the motion of one string. My point about the pickup detecting the motion of the string is true, and I suppose you could call this frequency summing. But I'm not an expert in this topic.
That's a choice by the programmer. Physical waves (as in waves in the real world, not in a computer simulation or formula) do not automatically scale in this manner. In fact, you can see this in Berkeman's link in post #4.
Unless you are artificially scaling the sum of the two tones in some manner then they will not have reduced amplitude. Indeed conservation of energy forbids it. Imagine 100 violinists playing slightly different notes. It's going to be LOUD despite the fact that the notes are all different.
The metal imaginary "pickups" are magnets that magnetise the string. There is one coil wound about all the magnets that detects the movement of any magnetised strings. All the string signals are summed in the one coil.
That system is linear, so the fundamentals and harmonics present, are all added together. If you consider every frequency present in the signal, and measure the RMS amplitude of each, with an FFT for example, you can estimate the power of each frequency.
The sum of those is the power in the combined signal. Although it will have rare extreme peaks, the RMS voltage of the combined signal, will represent the same power as the sum of all the individual frequencies. The mistake is to focus on a single momentary spike, when you should be squaring and averaging.
A guitar amplifier will distort and cross modulate everything to some extent. The amplifier front-end is designed to be non-linear. Why else would they use a 12AX7 when they could generate less harmonics with a 12AU7.
Ah, my mistake. I was under the impression that there was a separate coil for each string. I should have checked before I said something. :smile:
But the motion of a string is a sin wave with a frequency. Bounces up and down at specific speed like sine wave.
I saw the Berkeman's link and it shows that the two sound signals surpassed the value peak of "1". So how the pickup reduces it so it sounds the same.
What if the whole sound made of many sounds like 20 frequencies added to each other made that peak value is not "1" but "10" and the smallest value is "2" so the pickup sees that maks value is "10" and smallest is "2" so the output will be just a constant 0.7V output xD.
There must be some correlation to the sound value because adding each frequency must make some difference when the amplitude exceeds the values. Adding more frequencies will exceed the peak and the lowest value even more.
As I thought the sounds are summed in the coil.
But creating a circuit for the guitar like op amp I must know the exact input values but if there is a peak exceeds 1V but usually it is said maks is 1V then I dunno how the vibrations sinus that are similar to sound sinus exceeded the value "1" like in Berkeman's last link in post #4 then I don't get it as well as why using RMS and not care about peaks ? If peak is like "10" and minimum value of the signal is "2" which is larger than "1" and can happen because there are many frequencies added up.
And can result in Output constant voltage of 0.7V because pickup can maks do 0.7V or 1V. And watching the individual sound like E1 and E2 like in my link from post#1 still makes no sense why it is still under 0.7V but the sound can easily exceed "1" as same goes to vibration which vibrates up and down like sinus wave with fixed frequency.
I dunno I still don't get this part or problem when I can see that the values of 2 strings exceeds the value of "1" and what if I had more sinus waves. Same goes with the first link of post #1 where separate E1 and E2 aren't exceeding "1" weird or chord which is pulling 6 strings so 6 sounds it must exceed "1" but still maks is 0.5V or lower ??? Weird.
Real strings do not vibrate at a single frequency. They have many different frequencies called the normal modes, where the lowest frequency of the normal modes is called the fundamental frequency and all the others are the overtones.
The pickup doesn't reduce anything. It simply outputs a voltage based on the motion of the strings. Different notes can produce a large range of voltage outputs. For example, in the reference in your first post, the measured RMS voltage output in the first table of results varies between 12 mV and 128 mV depending on the note/chord and the pickup position. And this was in a controlled experiment. A real guitar would probably be subject to a much larger difference in min-max voltages depending on playstyle and such.
I wouldn't take these results as being 100% accurate. Without some machine to physically pluck the strings such that they vibrate the same for each test the results must be taken with a grain of salt. To quote the article:
"I tried to be as consistent as possible, but it's not easy. Every time you strike (or pluck) a string it will be a wee bit different. While it might sound very similar, the oscilloscope is totally unforgiving, and will show every tiny difference in the harmonic structure and the overall wave-shape. It's not really feasible to take many waveforms from each string and try to generate an average, as one ends up with a vast number of files that must be relevant to each test. This gets very messy, very quickly."
And:
"The oscilloscope shows the RMS level averaged across the full four second sweep, and while it's not particularly accurate, it is a useful indicator of what you can expect."
Okey but the pickup interprets high amplitude of the vibration ?
Like I've said before and looking at some pictures the amplitude of a sound/vibration exceeds the value "1" when there are multiple sounds/vibrations. How the pickup will interpret the vibration of a amplitude which pik is "100" in value and how it will interpret the different sound of a amplitude of value "10" ???
The amplitude value is inconsistent to what max pickup value can give. And the pickup is recreating the sound the strings vibrate. So the sound from vibration is the same at the voltage we get atleast the shape is similar/same. So what about the amplitude of vibration which is similar to sound because they add up so they exceed value "1" like "100" or lower but still how pickup interprets them ?
The term "interference" is normally used to describe a spatial effect as two or more signals (the same or very very near same frequency) contribute to the effective signal at different points. (Look up Young's Slits) What you get from one or more strings is just a number of signals at different frequencies coming down the same wire. Our ears interpret this as beats or just pleasant / unpleasant total sounds. Non-linearities (fuzz boxes / valve amplifiers etc ) generate new frequencies and (like the toothpaste out of the tube) will not go back into the original form.
But it's just a word and is often used in alternative ways outide of wave theory
Doesn't the sound add up ? I read something about superposition of Sound so I assumed it is something like Interference. That these sound add parts where they meet at like in my geogebra example.
But I still wonder how pickup works when the sum of all amplitudes from sound or vibration exceeds this value "1". Like the sum of all signals is "100" and what pickup will do with this peak. Or with many peaks because I said about one peak but what if I have many peaks or the single peak is very long.
This huge value from the vibration when the signals are summed is something that I can't imagine how pickup interprets it.
Xenon02 said:
The amplitude value is inconsistent to what max pickup value can give. And the pickup is recreating the sound the strings vibrate. So the sound from vibration is the same at the voltage we get at least the shape is similar/same. So what about the amplitude of vibration which is similar to sound because they add up so they exceed value "1" like "100" or lower but still how pickup interprets them ?
You really are confusing yourself.
The signal from the pickup, is the voltage between two wires, that appears across the resistance at the input to the amplifier. That voltage is the linear sum of all the movement, of all the strings, many different frequencies and each of those with a different amplitude varying with time.
Power is proportional to the square of the voltage. So we square the voltage, then take the mean, which will be positive. That mean is proportional to the power. We can find the equivalent positive voltage by taking the square root. That is why the voltage amplitude of an AC signal is called the RMS voltage, the Root of the Mean Square of the voltage.
If you take the combined signal, and measure the power of each frequency separately, they do sum to the total power of the combined signal.
Because energy is conserved, it is the square of voltage that is important.
When; a² + b² = c² ; it does not follow that; a + b = c .
The peak voltage amplitude of the combined signal is misleading, because you are summing in the voltage domain, not the power domain.
I still don't get it.
Why power now ? I mean I wanted to use this voltage from pickup for some guitar effect so to create electronic circuit so I have to know what is the input voltage rather than power I guess ?
But mainly let's use an example, because it might get easier.
This is the vibration of 4 sounds. The peak is "4" (I don't know the unit of the sound/vibration so I just say "4"), it consist of 4 sounds so adding them will result in this orange signal. It is correct to the superposition linked in post #9.
- So is this orange signal a power ?
- Will the pickup voltage signal will be similar to this orange signal ?
- What will pickup do to this "4" peak ? What will be the value in voltage of that peak ?
- Will a different peak like "10" have similar voltage value like "4" peak ?
- What has power domain to the voltage domain ? If orange signal is in power domain so square root of that top value will result in "2" (I might be wrong here).
- here I saw something about RMS but still peak is "4" RMS = +/- 2.8. It's a mean value in AC because normally mean value of the sine is 0, but yea RMS is a mean value for AC signals.
So I wanted to understand it using an example. Example that some sources provided like superposition of 2 signal and more or the link of the voltage value from the 1st post. I just wanted to know what pickup does to very high peak values.
Or maybe you are telling me this, but I just don't find it connected to my question or something. Because I asked about what happens to the peak and I read about power ;D Don't get me wrong here I just don't get the explanation because for sure I can't properly ask a question or my examples aren't clear so yea ;D
No, it is a sinusoid that goes negative, so it is not power.
The instantaneous voltage is 4.
I have no idea what that sentence means. "10" what, "4" what?
A number without units is meaningless.
If it is linear, it does nothing to them.
The peaks are nothing special, they are just coincidences in time of positive voltages. But they have fascinated your mind, and are now a distraction from everything that is important.
Plot a sinusoidal signal voltage.
Plot the square of that signal voltage. You will get a sinusoid, above the x-axis, with double the original frequency, that represents energy flow.
Now integrate that squared signal, divide by time, and you have the power of that original signal.
I mentioned I didn't know the unit :
I just saw on the videos the peak value of the sound which in my geogebra example is "4", without units, because I didn't see any in video/website etc. I only saw the final result which is my orange signal.
But I see that the part of voltage you've understood what did I mean by "4" or I guess you've understood. I just used the value from the example of that orange signal. And what did I mean by "10" ? Is what if peak value of that orange signal was not "4" but "10". So sound/vibration signal peak is equal to voltage peak value ? So vibration peak is "4" so voltage signal peak is also 4V ? Doesn't make that much sense though. So if the vibration peak value is "100" then the pickup will change that "100" peak into 100V peak voltage value.
The max voltage value from pickup can be 1V or 0.7V so how is it that instantaneous voltage is 4 ?
So indeed the sound/vibration signal will look the same as voltage signal from pickup, so pickup getting the orange signal will make the same looking signal but in voltage. I guess.
@Xenon02 i suspect you are getting confused for several reasons. The first is that doubling voltage does not equate doubling power. You need to realize that a vibrating string is being represented as a voltage. Doubling voltage quadruples power. Striking two strings instead of one is not quadrupling power. Math doesn't lie.
That's why I used example to see it.
What power ? What doubling ? Where did I confused/said that doubling the voltage equals doubling power ? I just showed what vibrating string gives which is the orange signal. How the pickup interprets the orange signal received from vibrating strings into voltage signal ? I sit the same ? How it interprets the peak of that vibration when it's value is "4" (I don't know the units).
The pickup receives the whole orange signal with this peak value of "4" and must transfer it into equivelant of the voltage signal. Pickup maks output voltage can be 1V. And pickup receives the input signal from vibration so the magnetic field movement and transfers this movement into voltage.
I still don't get it, so that's why I used the example so it would be clearer for me if it was used or rather say what is wrong or confusing in my text because I often refer to peak values of the input signal from vibration/sound wave received by the pickup, and how pickup interprets that input and makes it into output what happens to the peak value of "4" from then input when the max output signal can be 1V or 0.7V.
I don't know what do you mean by power here when I see only orange signal that is not the power nor the voltage signal it is just the input for the pickup that is made from the vibration, the sum of these vibrations is the orange signal so the pickup must change this input into voltage output. But the input has some high peak values which is "4" or can be "10", "1000" etc. But the pickup can have maks 1V output.
It is not logical that the peak values received by pickup doesn't match up with the output voltage. I don't see it. Neither I don't know where the power here shows up in the signals I just use the whole signal and not the mean value so I don't understand why power came up here, when I was talking about input and output signals. In which output is voltage signal and the input is the vibration signal both have the same shape but different amplitude.
So if you don't know the units how can you expect it to make sense if you don't know whether the units is watts (power) or volts? That is assuming you accept that what I said is true about doubling voltage is quadrupling power.
So if you don't know the units how can you expect it to make sense if you don't know whether the units a watts (power) or volts? That is assuming you accept that what I said is true about doubling voltage is quadrupling power.
I don't know if it's true about power and voltage.
I just said how the sinewaves looks like based on these links https://nsinstruments.com/principles/linear.html , , https://physics.stackexchange.com/questions/495511/vibration-in-a-guitar-when-playing-two-strings (here it shows how it looks like the sinuses of the vibration).
So I don't know the units I just accepted the peak value of those vibrations so I wondered how the pickup resolves this problem, the peak is high but there is no unit. So I don't know how to understand it differently when I see many websites mentioning about superpositions and these examples of sound in which it exceeds this mystical value "1" without unit in Y-axis of the function. So I just took it as an input value which peak is of value "4".
Whether the double the voltage gives the quadruple power. Maybe you tried to say that me accepting that this value does something is the same as accepting your statement ?
If so then how should I interpret the input signal values ? And how the pickup uses these values of that input signal like in my example, how to interpret this peak value of "4" of that orange signal ? How the pickup will interpret it ? As I said I just did what in other websites/videos did. So I am trying to use the example to understand it because without it I am lost.
Trust me. If you have a voltage driving a constant resistance you will dissipate X watts in the resistor. If you double the voltage you will dissipate 4X watts in the resistor. So whether you are displaying watts or volts makes a difference.
The power it took to make the string vibrate is X watts. Do that with two strings at the same time requires 2X watts. Now the string and transducer are not 100% efficient but there will be a fraction of that power that is transmitted from the transducer. If you measure the voltage it will NOT BE twice the RMS voltage with two strings compared to one. I have told you why several times.
Could you tell me then what my orange signal represents ? Because I guess this is an input from vibration yes ?
Because for now I understand that 1 string is X watts and 2 strings is 2X watts. So 1 string = X watt = voltage, 2 strings = 2X watts = not 2*voltage, not 4*voltage it is <2*voltage.
So why in websites it showed the sum of those sinuses and the peak values etc where that high, if I can know.
I also understand that 4x watts = 2*voltage (RMS and PEAK) ?
Again then what my signal represents ? And is it correct ? What will pickup do to this signal ?
https://nsinstruments.com/principles/linear.html this links shows signal that his maks value is 1.5
So It doesn't have units so I don't know what it is then. Or rather how to interpret it when you've said that 2xPower = 2 strings, here are 2 strings let's say stroke.
Similar with my example from post # 19. So yea how to interpret those ?
I don't know what your orange line represents and I'm not going to bother trying to find out. This is your project and if you are unable to conclude what you are looking at then you have no chance of designing circuits to create guitar effects. I assume based on your first post that this is what you want to do.
Ohms law should tell you what you need to know assuming you know how to apply it concerning volts vs watts in your plot.
E=IR
P=IE
The other formulas that are commonly known and used can be derived from the above two.
