How Does Parseval's Theorem Apply to Noise Amplitude Calculations?
  • Thread starter Thread starter MartynaJ
    Theorem
1 reply · 2K views
MartynaJ
You have a signal with a maximum frequency of 40 MHz. The average noise amplitude is 2 mV in the time domain. The noise is uniformly distributed from 0 to 40 MHz in the frequency domain. Now you apply a filter to remove all the frequency components above 10 MHz. What is the average amplitude of the noise in the filtered signal in the time domain?
##\int_\infty ^\infty {\left| f(x) \right|}^2 dx=\int_\infty ^\infty {\left| F(u) \right|}^2 du##
Before:
##\int_\infty ^\infty {\left| F_i(u) \right|}^2 du=\int_0 ^{40} a^2 du=40 a^2##
Therefore: ##a^2= \frac{1}{40}\int_\infty ^\infty {\left| F_i(u) \right|}^2 du##
After:
##\int_\infty ^\infty {\left| F_f(u) \right|}^2 du=\int_0 ^{10} a^2 du=10 a^2##
Therefore: ##a^2= \frac{1}{10}\int_\infty ^\infty {\left| F_f(u) \right|}^2 du##
Equating the two equations:
##\frac{1}{40}\int_\infty ^\infty {\left| F_i(u) \right|}^2 du=\frac{1}{10}\int_\infty ^\infty {\left| F_f(u) \right|}^2 du##
Therefore:
##\int_\infty ^\infty {\left| F_i(u) \right|}^2 du=4\int_\infty ^\infty {\left| F_f(u) \right|}^2 du##
using Parseval’s theorem which states that: ##\int_\infty ^\infty {\left| f(x) \right|}^2 dx=\int_\infty ^\infty {\left| F(u) \right|}^2 du##, we get:
##\int_\infty ^\infty {\left| f_i(x) \right|}^2 dx=4\int_\infty ^\infty {\left| f_f(x) \right|}^2 dx##
The question states that the average noise amplitude is 2 mV in the time domain. Does this mean that:
##\int_\infty ^\infty {\left| f_i(x) \right|}^2 dx=2## ?
Sorry I know this is an old thread, but are you still looking for an answer to this?
I think the 2 mV refers to [itex]|f(x)|[/itex], so the power would be proportional to [itex]|f(x)|^2[/itex] just like [itex]P = \frac{V^2}{R}[/itex]. I haven't seen the term 'noise amplitude' before to be honest, but it seems like they are asking for the rms value. We can say that the power is proportional to 4 of some arbitrary units (we don't need to worry about them given that the power spectral density is constant).
MartynaJ said:
Relevant Equations:: ##\int_\infty ^\infty {\left| f(x) \right|}^2 dx=\int_\infty ^\infty {\left| F(u) \right|}^2 du##
Before:
I think you can get to the end result sooner. We are told that the noise is uniformly distributed from 0 to 40 MHz (area of a rectangle, as you have found). Therefore, when only considering the noise from 0 to 10 MHz, you can immediately tell that the noise power is now 1/4 of what it previously was (there isn't necessarily a need to write out the integrals with [itex]a^2[/itex]).
Once we have the power is 1/4 of the previous value, we can find the noise amplitudes. You were basically at the solution. We want to find the value that solves: [tex]x^2 \times 4 = 4[/tex]
Hope that is of some help.
