How does temperature vary with power in a room?
The relationship between power supplied to an electric heater and the resulting room temperature is directly proportional, as established in the forum discussion. When the heater operates continuously, the room temperature stabilizes at a maximum value that correlates with the power input. The graph plotting power (x-axis) against temperature (y-axis) will display a linear relationship, indicating that higher power results in higher temperatures, assuming equilibrium is reached. Seasonal variations, such as summer and winter, do not affect this direct proportionality in the context of the heater's operation.
  • Understanding of basic thermodynamics principles
  • Familiarity with electric heating systems
  • Knowledge of graph plotting techniques
  • Concept of thermal equilibrium
  • Research the principles of thermal equilibrium in closed systems
  • Explore the characteristics of electric heaters and their power ratings
  • Learn about graphing techniques for linear relationships
  • Investigate seasonal effects on heating efficiency in different climates
Students studying physics, engineers working with heating systems, and anyone interested in the principles of thermodynamics and energy transfer.
baha
A typical room is heated with an electric heater on which the power (and thus heat output) can be varied. What do you think the relationship might be between the power supplied to the heater and the resulting warmer temperature the room reaches? Ie if you were to plot a graph of power vs temperature what would it look like? (assume that the radiator remains on at the chosen power and the temperature is recorded once the room has reached equilibrium)
This is the bonus question of my homework and is not for credit, however I thought it was really interesting. From my own general experience at home, I would guess the graph would be simply a straight line proportional graph. What do you think?
What do the axes of the graph measure? Hint: if the heater is always on, do you think the room temperature will be the same in summer and in winter?
The y-axis would be in oC and would show the values for the maximum temperatures that the room reached at equilibrium and the x-axis would be the power.
But is it directly proportional?
  • · Replies 25 ·
  • · Replies 109 ·
