Anshul J 2016
- 2
- 1
How does the current carrying capacity depends on the thickness of insulation of conductor ?
The discussion revolves around how the thickness of insulation on a conductor affects its current carrying capacity. Participants explore the physical effects of insulation on heat dissipation and the implications for wire performance, particularly in different environmental conditions.
Participants express differing views on the effects of insulation on heat dissipation and current capacity. There is no consensus on how insulation thickness impacts the wire's performance, and the discussion remains unresolved.
Participants reference concepts such as critical radius and heat transfer, but the discussion does not clarify the definitions or implications of these terms. The relationship between insulation thickness and current capacity is not fully resolved, with various assumptions and conditions presented.
Anshul J 2016 said:How does the current carrying capacity depends on the thickness of insulation of conductor ?
Anshul J 2016 said:1. Physical thing - Heating effect is produced in wire carrying current due to resistance...
2.When we insulate the wire, wire gets protected from outside temperature and heat generated inside the wire gets dissipated through insulation ( if insulation thickness is equal or less than critical radius.)
3. If insulation thickness is increases beyond the critical thickness than heat transfer decreases to surrounding.
4. In cold countries hot water pipes are insulated to prevent the loss of heat from water to outside where temperature is low and thus reducing the heat loss.
