How Does the Dirac Delta Function Solve the Differential Equation?
The discussion focuses on solving the differential equation ##Ay'' + By' + Cy = f(t)## using convolution techniques, specifically with the Dirac delta function. The initial condition is set as ##y_{0} = y'_{0} = 0##. The solution is derived for the case where ##f(t) = n## for ##t_{0} < t < t_{0} + \frac{1}{n}##, leading to a convolution integral that varies based on the value of ##t##. As ##n \rightarrow \infty##, the solution converges to ##\frac{1}{A(b-a)}(e^{a(t_{0}-t)} - e^{b(t_{0}-t)})## for ##t > t_{0}##, indicating the behavior of the system under impulse conditions.
  • Understanding of differential equations, specifically second-order linear equations.
  • Familiarity with convolution operations in the context of differential equations.
  • Knowledge of Laplace transforms and their application in solving differential equations.
  • Concept of the Dirac delta function and its role in impulse response analysis.
  • Study the properties and applications of the Dirac delta function in engineering and physics.
  • Learn about convolution integrals and their significance in solving linear differential equations.
  • Explore Laplace transforms in greater detail, focusing on their use in solving initial value problems.
  • Investigate the behavior of solutions to differential equations under varying initial conditions and forcing functions.
Students and professionals in mathematics, engineering, and physics who are dealing with differential equations, particularly those interested in convolution methods and impulse response analysis.
Summer95
Differential equation: ##Ay''+By'+Cy=f(t)## with ##y_{0}=y'_{0}=0##
Write the solution as a convolution (##a \neq b##). Let ##f(t)= n## for ##t_{0} < t < t_{0}+\frac{1}{n}##. Find y and then let ##n \rightarrow \infty##.
Then solve the differential equation with ##f(t)=\delta(t-t_{0})##.
Convolution (Boas)
Laplace Transforms (Boas)
So when I go through the first part with ##f(t)= n## for ##t_{0} < t < t_{0}+\frac{1}{n}## and do convolution I get ##y=\frac{1}{A(b-a)}\int_0^t(e^{-a(t-\tau)}-e^{-b(t-\tau)})f(\tau)d\tau## which has different cases depending on t:
0 if ##t<t_{0}##
##\frac{n}{A(b-a)}(\frac{1}{a}(1-e^{a(t_{0}-t)})-\frac{1}{b}(1-e^{b(t_{0}-t)}))## if ##t_{0}<t<t_{0}+\frac{1}{n}##
##\frac{n}{A(b-a)}(\frac{1}{a}(e^{-a(t-t_{0}-\frac{1}{n})}-e^{a(t_{0}-t)})-\frac{1}{b}(e^{-b(t-t_{0}-\frac{1}{n})}-e^{b(t_{0}-t)}))## if ##t>t_{0}+\frac{1}{n}##
I don't understand what happens as ##n\rightarrow \infty##. I know it should become
##\frac{1}{A(b-a)}(e^{a(t_{0}-t)}-e^{b(t_{0}-t)})## for ##t>t_{0}## because that is what I get when I use ##f(t)=\delta(t-t_{0})## from the beginning. But what happens to all the extra terms? And the n out front that goes to infinity?
Convolution (Boas)
0 if ##t<t_{0}##
Is ##f(t)## supposed to be zero for ##t < t_0## and ##t > t_0+\frac{1}{n}##?
Ray Vickson said:
Is f(t)f(t)f(t) supposed to be zero for t<t0t<t0t < t_0 and t>t0+1nt>t0+1nt > t_0+\frac{1}{n}?
Yes! Sorry I forgot to specify that.
  • · Replies 31 ·
